oil leak under engine
Old Jul 5, 2022 | 06:39 PM
Bether Betomax's Avatar
Unhappy oil leak under engine
this week I noted an oil leak under my GK5 engine, can It be a seal (gasket) or it can be more delicate issue? any recommendation would be great, thanks
Old Jul 6, 2022 | 06:31 PM
2015FITEX's Avatar
POSSIBLY it could be a rear main seal or the trans seal..round seals for shaft....not that it matters but is it engine oil or trans fluid...if you see more than a penny size drop you should get it fixed and or monitor what fluid is leaking...if its either of those seals it a big job
Old Jul 7, 2022 | 09:39 AM
Alco RS-1's Avatar
You might start by cleaning everything, then check it a week or two later and see if maybe you can tell its origin.
I don't know what kind of transmission you have, but the automatic (not CVT) trans in my 2013 has red fluid. The different fluid colors (engine oil vs trans fluid) can help determine the source.
Old Jul 11, 2022 | 10:21 PM
thank you, I'll check
Old Jul 11, 2022 | 10:22 PM
thanks a lot, will check with more attention
RoulantG
Jan 5, 2021 06:27 PM
jbbuilt
Aug 29, 2020 02:48 PM
Matthew Falzon
Nov 22, 2018 07:07 AM
BIGSAMV
Aug 31, 2011 08:05 PM
hondafit_03
Aug 13, 2011 11:05 PM
