How can I disable all doors unlocking when opening the driver's door from the inside?
As the title states, is it possible to disable having all the interior doors unlock when opening the driver's door from the inside with the vehicle running?
I'm not sure about GKs, but I assume it's similar to the GEs which have some combination of turning the key to different positions and holding the lock/ unlock button for some amount of time. I know that doesn't sound very helpful, but I think it's possible.
Perhaps I misunderstand the question, perhaps it depends on the model level? I have a '15 LX with a manual trans. SItting in the car with doors locked while it's running, the driver door can be unlocked simply by either using the door handle to open or unlock the switchbutton near the door handle, but you still need to use the handle to open it. Other locks remain locked. IF you're talking about unlocking just the driver door using the power lock button, I have no answer. If you just want it unlocked, just use the lock button in the door....if you want to unlock/open the door, just use the handle
Hi, thank you for the replies. I am trying to prevent all the doors from automatically unlocking when I open the drivers door from the inside (I suppose whether the car is running or not is irrelevant). I deliver pizzas and it would be really nice if I could keep my doors locked when I exit the vehicle in some situations. I tried manually unlocking the drivers door first with the door button but it did not work
It doesn't unlock when you just pull the handle to open it? Should unlock/ open and leave all other doors locked, at least it's been that way iin evey car I've owned including the Fit
LVFit
May 18, 2018 12:40 PM
