Issue with Defogging System
Old Aug 22, 2022 | 03:12 PM
wasserball's Avatar
In Houston, the weather can be quite hot and humid after a rain storm. The Honda Fit has a poor defogging system? I tried all different defogging modes, and temperature settings. Yes, I use the AC to reduce the interior moisture, but the fogging is on the outside. The windshiled starts fogging at the bottom to which I use the wipers to clear it. Both driver side and passenger side windows fog up too, but I don't know of a way to clear that. The fog is located around the outside rear view mirror. It can be safety hazard because the fog blocks the mirror from view. I tried clearing the fog by rolling down the windows, but the window seals do not wipe the fog off. Anyone have the same problem, any suggestions?
Old Aug 22, 2022 | 03:32 PM
TnTkr's Avatar
Fogging outside of the window is hot humid air facing the cool areas of windows caused by air-conditioning. You may reduce the side window fogging by closing the air vents on both ends of the dashboard or redirecting them away from the windows.
Old Aug 23, 2022 | 01:46 PM
wasserball's Avatar
Thanks! You are probably right.
Fat58
Nov 21, 2014 03:49 PM
captainhowdy
Feb 14, 2013 12:53 AM
davejulien
Mar 31, 2009 03:33 AM
pastafarian
Feb 5, 2008 10:49 PM
igeek
Feb 13, 2007 12:18 AM
