Will a 30" stove fit in a 2015 Fit?
Old Oct 17, 2022 | 06:19 PM
korgster's Avatar
Smile Will a 30" stove fit in a 2015 Fit?
Hi Folks,
Will a standard 30" gas stove fit in a 2015 Fit? I'm hoping to pick such a gas stove up but it's far away. I don't want to go pick it up to discover it won't fit.
Thanks for any tips!
Old Oct 17, 2022 | 10:08 PM
julianachos's Avatar
I am having a hard time imagining it will. But if you prove me wrong, show us pics!
Old Oct 17, 2022 | 10:31 PM
Drew21's Avatar
You presumably own a 2015 Fit and know the specific model of stove that you're shopping for, suggesting that you're in a better position than any of us to determine its dimensions.
Add a measuring tape to the equation and you will have the answer to your question.
Old Oct 17, 2022 | 10:44 PM
korgster's Avatar
Has this been done?
Thanks Drew, I did measure but a Fit is not a tidy perfectly rectangular box and neither is a stove. I don't yet know which 30" stove I'll be purchasing. I want to be prepared when I do find a potential second hand candidate.
I would feel better knowing that someone has done this successfully, fully understanding that it may not work but... is a possibility.
Looking forward to hear if anyone has done this.
Cheers.
Old Oct 19, 2022 | 07:27 AM
nayov's Avatar
I'm going to guess yes. I fit a cot bedspring set in it (72"?) and could not believe it. Pass seat forward and bed sideways. You'll have to hump it over the lip.
Old Oct 19, 2022 | 09:07 AM
korgster's Avatar
Thanks Nayov. Amazing that you fit such a bedspring set in it.
Yes, it will be a used oven, no boxes to contend with. Just the oven.
Old Oct 20, 2022 | 09:50 AM
Ultrawolf's Avatar
The constraint is going to be the hatch opening, which is shaped like a rounded off square. I measured my wife's '20 Fit and our 30 inch stove. Our stove is 30 inches wide and about 26 inches deep not counting the handle to open the stove. The hatch opening on the Fit looks like it could just handle getting a 30 inch wide by 30 inch tall object in. If you can tilt the stove on its side or back to load it, it should go in OK. You may scrape up the hatch opening because man-handling a heavy stove in there won't be easy. So, bring extra blankets to protect it if desired. Our stove is about 46 inches tall and the Fit has at least 50 inches of length on the load floor, so that should work too (you might have to adjust the recline your seats to be straight up). Also, bring some tools in case you have to remove a handle or some other oddball part. You might also be able to remove the stove door if you have too.
Old Oct 20, 2022 | 10:01 AM
korgster's Avatar
Thanks a million @Ultrawolf for the detailed analysis. This is extremely helpful and gives me the confidence it'll likely work. I will keep in mind the tip of possible door removal, and bring tools along. Back to the search for our second-hand stove... minus the worry regarding transportation
Once again, THANKS!
Old Oct 20, 2022 | 12:57 PM
BMWguy22's Avatar
OP needs to post pics of how this ordeal unraveled.
Old Oct 20, 2022 | 01:12 PM
bill bosco's Avatar
Once again, THANKS!
i just measured the hatch opening in mine , i'd say there would be no problem . possibly the door handle on the stove could be a problem , bring some tools , but most likely
the whole thing will go in . the hatch opening is quite tall , just under 30 inches
Old Oct 20, 2022 | 05:15 PM
Ultrawolf's Avatar
Thanks for your comments, korgster. I also have an '09 Fit that I bought new and have hauled a lot of odd items. For loading a heavy stove, you might want to lay the stove on a heavy blanket or strong tarp, then lift the corners of the blanket to lift the stove. It might be easier than trying to find something to grip on the stove. Having the blanket to lift by might make getting it out of the Fit again easier too.
Old Oct 22, 2022 | 08:38 PM
korgster's Avatar
Thanks @Ultrawolf ! We did it tonight LOL... We loaded it up using the "standard" method, no blankets, as I saw your msg after the mission was accomplished. Regardless, I much appreciated you taking the time to propose this.
There was some room to spare. Gotta love it! As I always say "Everything fits in the Fit" LOL.
Here's a photo:
Old Oct 23, 2022 | 07:57 AM
Ultrawolf's Avatar
That does look like it fit in there easily. Thanks for the photo!
Old Oct 23, 2022 | 09:42 AM
nayov's Avatar
Nice. Looks like there was plenty of space. Here's a pic of the contents from my mother's living space at a nursing home. I know it's impossible to visualize without being there for context , but it's astonishing everything fit and that was with sloppy organization.
Old Oct 23, 2022 | 11:51 AM
korgster's Avatar
LOL! Thanks for sharing @nayov ... Can't beat the Fit!
Old Oct 23, 2022 | 06:48 PM
BMWguy22's Avatar
The FIT is really an amazing little machine.
It's a real shame they don't make them for the N. American market anymore!
Old Oct 23, 2022 | 06:55 PM
korgster's Avatar
Agree. I'm hoping it'll be reintroduced by the time we need a new one. We take good care of our cars and don't replace them before they're 10-15 years old.
Old Oct 29, 2022 | 08:21 PM
Breezer's Avatar
Glad to see it Fit.
I am always amazed at what I can get into mine.
Old Oct 29, 2022 | 08:38 PM
Amazing! Glad to see it actually fit
Old Oct 30, 2022 | 10:12 AM
Brain Champagne's Avatar
I would have thought it's the other way around- that you could fit a Honda Fit inside a 30" stove.
Fit Pal
Mar 14, 2016 04:00 PM
jodfie
Dec 26, 2014 01:46 AM
shephrd
Jul 24, 2014 01:19 PM
TCroly
Jun 9, 2014 11:47 PM
