Better cornering and handling mods?
Old Dec 5, 2022 | 06:22 AM
Kiju's Avatar
Question Better cornering and handling mods?
Hey!
Currently have a:
RSB (17mm) Hardrace
185/60/15 Goodyear; 15x6.5 +40 Rota; *might upsize to 195/55/16*
What mods do I need to make my GK handle better?
Coilovers are out of the question because of my location (High humps, rough roads, steep roads).
I'm planning on buying a Front Sway Bar and a Front Strut Bar but I've seen comments that Front Sway Bar doesn't do anything and it basically makes it back to stock with the RSB, same with the Front Strut Bar. Is this true?
Thanks!
Old Dec 5, 2022 | 07:26 PM
Action Jackson's Avatar
Front strut bar will be a big improvement. It almost feels like when you install proper stiffer lowering springs for the first time and notice how responsive the car is.
Old Dec 6, 2022 | 01:43 PM
bill bosco's Avatar
i think because of the front weight bias on the fit a heavier front bar would be an improvement . i put one on the front of my '02 SI ( after installing
a bigger one in the rear ) and it really tightened up the steering . on the fit i'd have one on the back first . i've got one on mine along with some chassis
bracing . check out Ultra Racing , they have a line of braces . stiffening up the body does wonders including firming up the ride , steering responce , stability
and ride quality .
Old Dec 15, 2022 | 08:59 AM
SkylineFTW97's Avatar
Definitely do tires first. I have 195s on mine (Yokohama Avid Ascent GTs) and it helps. I'm biased, but I work at a Honda dealership and I've driven enough GK5s with the stock Firestones to say that I'm not a fan. I feel much more confident on my Yokohama's, and they wear much better too. Good grip in the dry and wet (I live in Maryland where heavy rain is common).
Always start with tires when it comes to handling. It will make a bigger difference than anything else.
Old Dec 19, 2022 | 03:51 PM
Shadow Smith's Avatar
195/XX/16?
Will try 195s next go around.
Steve
Old Jan 11, 2023 | 07:32 PM
Originally Posted by Shadow Smith
195/XX/16?
Steve
My bad, 195/55R16s.
Wolfvision
Dec 16, 2010 04:36 AM
Sylak
Aug 7, 2010 01:30 PM
mikejet
Jan 29, 2009 05:28 PM
Sam Misled
Nov 30, 2008 08:48 PM
tiF adnoH
May 26, 2006 11:03 PM
