PCV valve
Old May 11, 2023 | 02:10 PM
MrDucky's Avatar
PCV valve
Does any have any videos or information on replacing the PCV valve on the 3rd gen Fit?
Thanks.
Old May 17, 2023 | 12:10 PM
elkaku's Avatar
I try to replace mine between every 1 ½ to 2 years... And I also drilled out the OEM one and used it as a fitting since it is a pain in the butt removing it... And bought one that's installed in line and works perfectly!!
Its located below the intake manifold and a long socket and wobbly joint will be better for removal...
On USDM or MXDM the PCV is number 3, and the corresponding washer is number 10....
PCV I bought
Old May 17, 2023 | 04:22 PM
MrDucky's Avatar
Thank you for your help!
Old May 17, 2023 | 08:23 PM
elkaku's Avatar
You're welcome.... That's the point of these forums!!
Old May 18, 2023 | 02:36 AM
2015FITEX's Avatar
whats 4 ???????????????
Old May 19, 2023 | 09:52 AM
elkaku's Avatar
4 is another type of PCV... There are some models that come with a plug like valve, and others are screw on ..... On MY particular one is the screw type.... I'm not sure which market uses the plug like one....
Mine is a Mexican made chalupa American version living in Puerto Rico 🤪
mowfixer
Apr 30, 2022 05:14 PM
Kevin Evans
Feb 11, 2018 10:48 AM
amberd03
Aug 20, 2017 11:57 AM
codenamezero
Sep 21, 2016 08:23 AM
icedmocha
Feb 9, 2015 05:58 PM
