deflation warning system
Old May 24, 2023 | 02:29 PM
77alex's Avatar
Hello
A wheel warning light came on
I checked, all wheels are fine
I reset
I drove the car for about a week, and the light came on again
I think the system turns on after the car enters a bump in the road
Does anyone have experience with this?
Thanks
Old May 27, 2023 | 03:12 PM
exl500's Avatar
I had a recurring false TPMS reading on the OEM tires that went away when they were replaced. That could be your problem.
Old May 31, 2023 | 11:34 AM
Alfa38's Avatar
Check your ABS sensors to make sure one isn't loose, or a loose or corroded connector. The 3rd gen Fits use indirect TPMS method of measurment based on wheel speed. It could be an issue with one of the wheel speed (ABS) sensors.
Also, you may have to reset multiple times for the system to register. See info in this thread:
https://www.fitfreak.net/forums/3rd-...uestion-2.html
Old May 31, 2023 | 01:37 PM
wasserball's Avatar
Yes, it happens to me when I replaced old tires, or when the tires are rotated. Even when the tires are inflated to spec pressure the TPMS came on, WTF? The only thing you can do is keep driving and keep resetting. After a few resets, the Fit finally figured out that the tire pressure is OK and no more TPMS warning.
Old May 31, 2023 | 03:23 PM
TnTkr's Avatar
My TPMS warning started to appear time to time especially during longer highway trips, and eventually I found out that brake pad was slightly dragging and that wheel became warmer than three others. Cleaning the pads and slides solved the problem.
Tfox1042
Apr 1, 2022 12:28 PM
nampuchi
Apr 6, 2021 03:10 PM
damoaten
Feb 28, 2013 06:40 AM
geepondy2
Jan 14, 2012 09:12 PM
