Oxygen sensor brands
Old Aug 22, 2023 | 08:01 AM
gcentrel's Avatar
Hello, I have a 2015 Honda Fit that reports a OBD code P0141. I replaced the O2 sensor with a Walker brand vs. the original Denso that is $100 more. The continuity checks seem ok. I think it's my PCM. Has anyone out there used an off brand O2 sensor in their Honda?
Old Aug 22, 2023 | 12:06 PM
NWCH's Avatar
I would only use OEM Denso.
Walker is not a trustworthy brand in any way. And you get what you pay for...
Old Aug 22, 2023 | 03:04 PM
woof's Avatar
Originally Posted by NWCH
I would only use OEM Denso..
I'd agree.
Old Aug 22, 2023 | 10:44 PM
2015FITEX's Avatar
that code wont leave you stranded....weird...maybe the resistance is not what the car expects, id get another o2 sensor before ripping the ecu apart...and check for any chafed wires...and give the connector a good clean/eyeball
Old Aug 24, 2023 | 09:19 AM
gcentrel's Avatar
Denso O2 sensor didn't fix the problem 🤷‍♂️
I bought the Denso... didn't fix it... off to replacing the ECU/PCM... I'm thinking about buying the "Thinkdiag" programmer... used ECUs are cheap.
Old Aug 24, 2023 | 11:43 PM
2015FITEX's Avatar
it looks like the software is 70 dollars a year?
i didnt think swapping ecus was plug and play but NEVER done it....isnt the vin and the mileage in it?
maybe check you have heater circuit voltage ?
https://www.700r4transmissionhq.com/p0141-honda-fit/
Old Aug 25, 2023 | 07:53 AM
gcentrel's Avatar
You are correct... ECUs are not plug and play. I will need to program it. I am looking at a Thinkdiag 2 engine programmer to do it myself or pay someone else to do it. It's over $200 if the dealer does it. I found a used one on ebay with the exact part number for less than $100. By the way, I did spend another $200 for the dealer to tell me something I already knew, they checked the voltage and determined it's either the sensor or the ECU.
Regarding sensor brands... I think the cheap Walker sensor would work fine. After I fix the car, I may install the $50 Walker sensor back into the car just to see if the $230 Denso sensor really makes a difference.
Follow up:
I bought the Thinkdiag 2 bidirectional OBD2 code reader. The software needs work, I had to rerun it a couple times to figure it out, but I was able to program the ECU, make another key, reset the tire pressure light, set the VIN so the radio works and pass emissions 😎 ... woohoo!🍻
rwjd
Apr 12, 2024 11:54 AM
fitowner10
Mar 9, 2019 09:02 PM
stubuzz100
Mar 4, 2012 10:15 PM
Hirvi
Nov 25, 2011 11:11 PM
leonine
Nov 9, 2006 11:23 AM
