Is this much motor movement an issue?
Old Nov 12, 2023 | 04:28 PM
pfprojects's Avatar
Question Is this much motor movement an issue?
I've had this pop/click sound when the engine is lugged down a bit harder when I start in 1st gear from a stop. I can also sometimes get it if I change to second gear and floor it. I'm thinking it's a high torque related sound. I got a video of the engine bay while revving the engine and pulling up partially on the clutch in 1st gear. Does this seem like too much motor movement? I'm thinking I'll want to replace the motor mounts if so. Thanks!
Old Nov 13, 2023 | 10:00 PM
Virulence's Avatar
Yeah, that is way too much motor movement. Check the mounts. I can clearly see the passenger side engine mount flexing in the video.
Also I don't know if it's the microphone quality but your engine seems to be running a bit rough. Is it cold outside?
Austin Erwin
Aug 13, 2019 07:42 AM
Puce Brosnan
Apr 7, 2016 08:08 AM
tonkatsu
Dec 24, 2014 07:58 PM
wpgfit
Apr 28, 2008 12:29 PM
accupix
Mar 31, 2006 07:25 PM
