Keyless start sustem problem - engine won’t turn off
Old Feb 18, 2024 | 01:23 PM
Robble's Avatar
Warning light came on as I was driving to work.
got to work and engine won’t turn off. Fans turn off but dash lights are on and engine still running.
sitting in parking lot at work wondering what to do. Dealerships are closed today.
any ideas?
thanks!
Old Feb 18, 2024 | 01:57 PM
bargainguy's Avatar
Welcome. In a pinch, I'd disconnect the negative battery terminal temporarily to kill the engine. Then you can decide on options like towing or possibly roadside service if you need a jump to get it started again.
Old Feb 18, 2024 | 03:05 PM
Robble's Avatar
Been reading up and seems most likely a bad ignition switch. I’ve ordered a new one from Amazon that arrives by 8am tomorrow.
gonna just let it idle while at work. It’s locked up and parked near the door where I can see it.
Don’t wanna chance it not starting and leaving me stranded here.
Old Feb 18, 2024 | 04:18 PM
bargainguy's Avatar
OK, but a heads up. You can burn a hole through your catalytic converter if you let the engine run too long without moving the vehicle.
Old Feb 18, 2024 | 10:29 PM
Robble's Avatar
So got home and pulled fuel pump fuse then disconnected the battery.
will change out the switch when it arrivesz
Old Feb 18, 2024 | 10:30 PM
Robble's Avatar
i think someone has been pulling your leg. That’s simply not true.
Old Feb 19, 2024 | 09:28 AM
bargainguy's Avatar
Excessive idling drops an enormous amount of heat into the cat that is not dissipated because the car isn't moving.
High temps can cause the catalyst to melt or lose its surface area. When that happens, you get a hole.
But don't take my word for it. You seem disinclined to accept anything I've said so far. Why start now?
Old Feb 19, 2024 | 09:47 AM
NWCH's Avatar
Um no, that is not even close to true. Who told you that nonsense? lol
That is probably the dumbest thing I have read all week.
Old Feb 19, 2024 | 09:49 AM
NWCH's Avatar
Once again. Not true at all. You are not melting holes in metal that are meant to take the heat. Especially when these car don't buildup heat to start with. Holes don't just melt in your exhaust from idling. Even posting that here is just stupid. smh
Old Feb 19, 2024 | 09:54 PM
DaBinChe's Avatar
idling is when everything runs the coldest, the higher the RPM the hotter...if anything too long cold running clogs up the cat
Old Feb 20, 2024 | 01:07 AM
Robble's Avatar
Well, your first bit of advice was to turn off the engine (by disconnecting the battery - which would not turn off the car btw) and tow it home or call roadside if I needed a jump when I specifically said I didn’t want to be stranded.. then you came up with complete nonsense about melting the catalytic converter.
That’s kinda 3 strikes…
Old Feb 20, 2024 | 01:14 AM
Robble's Avatar
Got the new switch in. I’ll install it on Wednesday when I have a day off.
string3599
Apr 22, 2018 01:04 PM
puffysweater
Apr 28, 2017 11:35 PM
Padawan
Dec 18, 2014 08:13 AM
redfit_pr
Mar 2, 2010 06:10 PM
pastafarian
Mar 27, 2008 05:36 AM
