Honda Fit GP-6 (Tyre Replacement from 185-60-15)
Old Jun 19, 2024 | 06:36 AM
Kashif Ahmed's Avatar
Hi all
Can any one advise me what alternate size can i use other than 185-60-15, i have tried 185-60-15.
any comments about 195-60-15 from 185-60-15
Old Jun 20, 2024 | 07:03 PM
saveMT's Avatar
Going from 185/60R15 to 195/60R15 will raise the car 6mm and make your speedo read 2% low.
But I'd say it's acceptable for most people. 195 wide with 60% profile on a stock 6" wide rims will be pretty cushy.
It'll of course depend on the tire choice, and it's relative, too. I mean, back in the 90's, 60% profile tires were considered "low profile."
I myself am running 195/55R16 on my EX (stock is 185/55R16), but on 7" wide rims. I actually like the slight increase in ground clearance.
Old Sep 23, 2024 | 12:21 AM
Jimmyizkewl's Avatar
going from 185 to 195 will make the wheelbase wider not height, especially if theyre both still 60r15
Old Sep 23, 2024 | 06:53 AM
saveMT's Avatar
Originally Posted by Jimmyizkewl
going from 185 to 195 will make the wheelbase wider not height, especially if they're both still 60r15
Wheelbase is the distance between front and rear axles. Nothing you do with wheels and tires can change that.
60 number is PERCENT of width. 60% of 185mm is 111mm. 60% of 195mm is 117mm. That's why 195/60R15 will raise the car by 6mm compared to 185/60R15.
There are many sites with easy to understand information. I tend to use https://www.wheel-size.com/
Old Sep 23, 2024 | 12:26 PM
GrE8_Fit's Avatar
I drove with 195/60/15's on the stock wheels (6"? 5.5"?) for about a year and it was terrible.
Old Sep 23, 2024 | 12:55 PM
saveMT's Avatar
Can you elaborate on, "terrible?" Bouncy? I generally like "more sidewalls." I wouldn't consider 195/60 would be "too much sidewall."
I actually have more sidewall on my Civic (215/55R16) at 118.25mm, vs. 117mm on 195/60R15, although I guess they're not equivalent since Civic tires are 20mm wider. Tires themselves make a huge difference also (brand, model).
Note stock wheels on GK are all 6" wide. LX: 15x6, EX & Sport 16x6. Note EX and Sport wheels have different offsets. Sport wheel sticks out further by 5mm.
Old Sep 23, 2024 | 02:15 PM
bill bosco's Avatar
definitely 195 55 15 , tire diameter is just a tad smaller but close enough and way closer than 195 60 series tire . if you ever upgrade
to an after market rim go with a 7" width . 40mm offset works just fine . with a 195 tire gives it a nicer stance , feels more stable on the
highway too . i'm still getting 35 + mph mixed driving with that setup .
Old Sep 24, 2024 | 05:59 PM
yea i made a whoopsie on that one, my apologies!
Old Dec 28, 2024 | 04:47 PM
Blitz8448's Avatar
185/55/16 et40 7"
Hello,
Can I ask what did you mean but your last comment "i'm still getting 35 + mph mixed driving with that setup"?
Also I have a fit 3rd gen, currently on 185/60/15 ET50 6J, I'm looking to buy an aftermarket one 185/55/16 ET40 7J but looking on offset calculator and OE recommendations is saying approach with caution but you've mentioned above you have ET40 fitted on yours... Can you give some advice please?
Old Dec 28, 2024 | 06:36 PM
bill bosco's Avatar
Originally Posted by Blitz8448
Hello,
in other words , compared to the stock sized tire , i'm getting the same 35 + mileage average . i get in the mid forties on the highway . that's with the 6 spd
08FITFREK
May 19, 2025 12:13 AM
wackyflik
Oct 4, 2013 09:58 AM
Mr. Shine
Apr 12, 2010 07:41 PM
jono21
Aug 8, 2008 06:41 PM
