Fit TPS Wiring.
Old Aug 30, 2024 | 04:55 PM
UncleChookie's Avatar
Fit TPS Wiring.
I pulled a wire out of the TPS wire connector. I am trying to make sure my new harness has the correct connections and current to each pin. It is a 6 pin connector and I need to knkw how to test each wire to make sure it is properly connected. I know that the “power” wore is supposed to read around 5 volts. What are all the other wires supposed to read? And since it is a push button start, how do I turn the key on to test the wires? Do I press the button without foot on brake and that is it? Or do I have to do something else?
agent14andahalf
Jan 10, 2020 05:23 PM
vron3301
Fit I.C.E.
Nov 24, 2019 04:31 PM
ekimox
Dec 17, 2013 07:53 PM
Vash
Dec 15, 2011 03:50 AM
2010Fit
Jul 23, 2010 11:09 AM
