ABS/Wheel Speed Sensor issue after changing driveshaft
Old Mar 10, 2025 | 09:29 AM
Hondaddy's Avatar
Hi All,
I have a 2014 Fit Hybrid GP5. I recently changed my front left driveshaft due to worn CV joints and since the replacement, I'm getting ABS, VSA, Hillstart Assist, Traction Control, etc. lights on the dash. I only disconnected the suspension shock from the hub to allow installing. I have inspected the ABS sensors itself and it appears to be in good condition. The only thing I can think of is that I possibly strained some of the cables going to the sensor when I was removing/installing the driveshaft.
I have a fairly basic OBD2 reader, which is showing no codes. Anybody got any experience with this?
Old Mar 11, 2025 | 11:00 AM
woodenpickle's Avatar
I took my wife's 2015 Pilot in a month or so ago to get the struts replaced. After getting it back, we kept getting the ABS and traction dash lights popping up. I only have a basic OBD reader as well, so I took it to Autozone and they put their fancy scanner on it and said the left front ABS sensor was bad. I took the wheel off and noticed that the little bracket that holds the ABS sensor cable up at the top of the wheel well was bent up and kinda kinking the cable. I bent it back down and the dash lights all went off and have stayed off since.
I know it's not a FIT, but I'd imagine the ABS sensors are fairly similar.. and it does seem like the cables for them are pretty sensitive to bending/kinking.
Old Mar 11, 2025 | 05:04 PM
Hondaddy's Avatar
I'll have a look at the wiring this weekend. If I can't see any obvious damage, I'll try investigating further with a multimeter. I'm just hoping I having cracked the reluctor ring.
Jmf23462
May 7, 2024 05:12 PM
Sunflow99
Dec 10, 2023 07:41 PM
justworkdammnit
Nov 22, 2019 04:04 AM
andyd
Feb 23, 2012 11:55 AM
glen62
Jul 1, 2010 10:28 PM
