Trans/engine mounts
Old Apr 18, 2025 | 10:51 PM
Jsargent1's Avatar
Trans/engine mounts
Going to be doing all three mounts weather permitting this weekend.
The engine mount and rear mount look easy, has anyone done the transmission mount? Looks like I have to move the ECM out of the way. Can anyone enlighten me on the steps or is it just as straight forward as it looks?
Im fairly confident mechanically, just need new suspension all around, and valve lash and the valve cover doesn’t leak! lol
thank you!
Old Apr 22, 2025 | 01:50 AM
2015LXFIT's Avatar
Super straight forwards;
Support driver's side drivetrain (transmission)
Remove all components above mount - ECM if you need to; airbox etc.
Remove mount.
You may need to lower the trans. side if there's side bolts. Just play around with it and don't overthink it. You'll be alright. Good luck!
Dlee
Oct 12, 2022 06:43 PM
ChuckDustin
Apr 12, 2019 12:47 PM
Marrk
Aug 13, 2017 04:25 PM
allmotormark
Oct 10, 2014 01:16 PM
CuTeBoi
May 4, 2011 06:57 PM
