Keyless Start System Problem warning
Old Oct 24, 2025 | 01:17 PM
ogp's Avatar
ogp
I recently started getting the "Keyless Start System Problem" warning on my dash. My proximity lock/unlock no longer works. I have no issues starting the car with a single push of the start/stop button and can lock/unlock with the fob buttons. Does this still point to the ignition button being the problem and needing replaced? This is for a '18 EX manual.
Old Oct 25, 2025 | 06:47 PM
bobski's Avatar
Get someone to check the error codes.
Old Oct 26, 2025 | 12:59 AM
Chitown Fit's Avatar
Key FOB Battery.
Try changing the key fob battery.
Battery size is 2032.
Old Oct 26, 2025 | 08:07 AM
bobski's Avatar
Worth a shot, but our 2020 EX has a specific low-battery message on the gauge cluster.
Old Oct 26, 2025 | 04:07 PM
ogp's Avatar
ogp
Torque shows no codes.
Happens with both fobs, not just one. Plus I've seen the separate low battery warning in the past, this is not it.
Old Oct 26, 2025 | 06:00 PM
bobski's Avatar
A little searching on other Honda sites says this is common when one of the car's antennas is unplugged.
Old Oct 27, 2025 | 10:53 AM
ogp's Avatar
ogp
Can you point me to where you see this? Everything I see points to the start/stop button.
Old Oct 27, 2025 | 12:21 PM
bobski's Avatar
I searched the web for "keyless start system problem honda". Read through some posts on forums for other vehicles, some reddit posts.
... Which contains one of the LF (low frequency) antennas for the keyless access system. The 2019 wiring diagrams also shows LF antennas in each front outer door handle - I suspect these are near-field/RFID type antennas that require the keyfob be held within a few feet (maybe a few inches?) of the antenna. There's also three antennas listed that are not marked as LF - under the center of the dash, center front of the luggage compartment floor, and centered behind the rear bumper cover. I think those three are responsible for medium-range range detection of the keyfob. The keyless access unit (near the gauge cluster) might have its own built-in antenna for the long-range keyfob button functions, or the existing antennas might do it.
Old Jan 3, 2026 | 01:42 PM
Kimochibern's Avatar
I had this happen to me two days after I got my GK. I just bought the DeoxIT D5 spray and clean out my START/STOP button after I removed it from my dash. I haven't had that warning light show up ever since.
Old Jan 10, 2026 | 11:05 AM
ogp's Avatar
ogp
I'll have to give that a shot. I tried two generic buttons from Amazon (initially I purchased the wrong version and the second I couldn't get the pins aligned in the connection) as a cheap alternative before buying OEM. So I'm pretty versed in taking it apart now.
Old Jan 10, 2026 | 03:02 PM
Start Button Recall.
There's a recall for the push start button.
A Honda Dealer will replace the start button for Free. No charge.
How do I know?
I had mine replaced.
Free. No charge.
Old Jan 12, 2026 | 12:30 PM
ogp's Avatar
ogp
How do I know?
Free. No charge.
Do you have NHTSA recall info? I have not received any notices. I had the car in for fuel pump recall at the dealer and the warning was on the dash but they didn't offer any solutions.
Old Jan 12, 2026 | 12:51 PM
Go To Your Local Honda Dealer.
Check with your local Honda Dealer.
Old Jan 14, 2026 | 05:04 AM
nayov's Avatar
It was a TSB (Technical Service Bulletin), not a recall and it has since expired.
​​​​​​https://static.nhtsa.gov/odi/tsbs/20...84317-0001.pdf
Nakajimanoah
Aug 30, 2025 03:27 PM
Heinrich Zehrt
Dec 17, 2022 12:57 AM
Seth J Chatfield
Sep 28, 2021 01:40 PM
ElliottAugust
Apr 4, 2020 12:46 PM
BMO
Sep 27, 2014 01:16 PM
