2016 Honda Fit Rear Jack Placement
Old Jan 20, 2026 | 08:49 AM
FitHit's Avatar
I want to lift the rear end up on my 2016 Honda fit so I can place jack stands under the left and right side re-enforced frame. Getting ready to replace the rear drum shoes. Apparently some Honda's have a re-enforced frame near the back, but my Honda Fit does not.
So, some people suggest lifting it by the metal tow hook while others seem to state not to do that. Still others seem to suggest there is a metal cone type place to lift the back or another plate. I've looked pretty good and could find neither.
Does anyone have the same model, 2016 Honda Fit EX and know if and where it can be raised? I know even model's by year can change a simple feature.
Old Jan 20, 2026 | 10:53 AM
2Rismo2's Avatar
I've always used the rest tow hook.
Old Jan 21, 2026 | 07:15 AM
ScottK's Avatar
From the Chilton Library for 2016 Honda FIT
Old Jan 21, 2026 | 10:29 AM
FitHit's Avatar
Picture is worth a thousand words. Thank you.
Old Jan 21, 2026 | 01:20 PM
Mister Coffee's Avatar
Honda Service Manual for the GE
Old Jan 21, 2026 | 05:12 PM
FitHit's Avatar
GE? Thank you. I notice no picture of the rear.
Old Jan 22, 2026 | 11:23 AM
Right side of the page. Letters B and C.
Old Jan 22, 2026 | 12:32 PM
FitHit's Avatar
I saw that; but on my 2016 Honda Fit Ex, that B and C does not exist. Just the tow hook. Just crawled on the floor to confirm once again. :-)
Wish it did have that spot.
Old Jan 24, 2026 | 12:57 PM
I recall very clearly using the tow hook as a jacking point on my GD. Since then, I've been using a four-point lift in a shop.
Tow hook should be okay as long as the front two wheels are on the ground and you are working on a level surface. (Although every time I write that, I wish I had a clear confirmation from Honda that it was a proper lift point.)
Old Jan 24, 2026 | 01:29 PM
Drew21's Avatar
See ScottK's post above with a schematic from the Chilton's manual confirming that the tow hook is the correct lift point for a 2016 Fit.
Old Jan 25, 2026 | 11:52 PM
MTLian's Avatar
pfff. Showoff
for us plebeians still rolling around in the dirt using jack stands, I can confirm I have also frequently jacked up my GD and GK from the tow hook.
as far as safety, before (and after) you get the jack stands under the pinch welds, please do the following:
-put the car in gear if MT or in park for AT. I put my car in reverse (MT) but any gear is probably fine. The jack will definitely want to roll forwards while you jack the car up so make sure your jack can roll around on its wheels and isn’t stuck in a crack.
-put wheel chocks in front of the front wheels. If you have em, you could consider chocking both sides of the wheels for added safety. I usually just choc one wheel but do as I say, not as I do
stay safe and have fun wrenchin’
Old Jan 26, 2026 | 12:49 AM
Originally Posted by MTLian
pfff. Showoff
You have understood me, sir.
I have spent my entire life "rolling around in the dirt." It was dumb luck that I found yourdreamgarage, and when this guy goes belly up, I'll be back on my back.
It's over for me. I'm tired of trying to find a solution. Next stop for me is to buy a house and install a lift. Period.
Cupi11
Jan 2, 2025 01:44 AM
magicmermaid
May 25, 2020 04:17 AM
TorontoBoy
Dec 13, 2016 12:49 AM
Newbiefitfreak
Oct 5, 2015 01:47 PM
shoyu
Apr 6, 2015 10:30 PM
