Need help checking tire pressures 2020:fit EX
Old Mar 8, 2026 | 01:56 PM
mharnisch's Avatar
I need to check tire pressures on my Fit. Is there a way to use the maintenance display to do this or do I just have to use a pressure gauge to manually check each tire? Thanks for your help.
Old Mar 8, 2026 | 02:29 PM
bargainguy's Avatar
You have to check each one manually.
The TPMS system doesn't display anything with regard to individual tire pressure. It's a passive system based off ABS.
I don't own a GK5 anymore, but I remember that the TPMS would alert when any tire got to 22 lb. or less.
Usually when pressure got that low, it was easy to tell which tire was low just by looking at it.
But there were also times when the TPMS would alert even with all tires properly inflated. That's why I hate this implementation of passive TPMS.
Old Mar 8, 2026 | 03:23 PM
Chitown Fit's Avatar
Tire Pressure Check.
Check each tire with a Tire Pressure Gauge.
I put 40 psi in each tire.
Old Mar 10, 2026 | 09:17 PM
mharnisch's Avatar
I was afraid that was the answer I would get. Thanks all for your replies.
japspeed
Apr 11, 2014 09:29 AM
Starscream
Mar 26, 2012 10:14 PM
Jubei
Nov 4, 2009 08:25 PM
Len1
Sep 11, 2009 07:17 PM
