2015 Shudder When Accelerating
Old Mar 29, 2026 | 06:28 PM
Horiz0n's Avatar
Question 2015 Shudder When Accelerating
Hi,
I have a 2015 with 137,000 miles, and a few days ago I started noticing a shudder when accelerating, and today it has become worse. From the outside, it sounds like rattling. The shuddering stops when coasting, it is at its worst when accelerating from a stop but still happens when you speed up while already moving, up until around 40MPH where after that it is not really noticeable. Up until yesterday, it was just a consistent judder when accelerating, but today it has some worse judders where it almost feels like a slipping.
Here is a list of things I have checked:
  • When outside of the car, I can hear it from both sides of the car.
  • RPM seems consistent when it is juddering.
  • I can also feel it though the pedal and steering wheel.
  • When I put the car on jack stands, put the car in drive, and accelerate (wheels in the air) I do not hear/feel it.
  • Transmission fluid is at the correct level (HFC-2, changed 10,000 miles ago), no metal shavings or burnt smell when I opened the fill plug to check the level.
  • Oil was changed a couple of weeks ago, no issues following that until a couple of days ago.
  • Fuel injectors were replaced under the extended warranty on them around a year ago.
  • The drivers side CV axel is solid, no movement.
  • The passenger side CV axel has slight in and out play, but no up/down or side to side play.
  • With the car on the ground, I started it, put it in drive and while holding the brake, and revved the engine to try to test the engine mounts, I didn’t not hear the rattle (I know this is not a perfect test).
  • It also happens in reverse.
  • I have checked engine mounts, control arm bushings and the torque mount, nothing looks failed, ripped or has any excessive play.
  • No codes when doing a full system scan with a BlueDriver.
I have a feeling it is something between the transmission and the wheels. Any ideas as to what I can check?
Thank you in advance.
Old Apr 6, 2026 | 12:09 PM
bobski's Avatar
There shouldn't be. The outboard joint uses a precision ball bearing design that shouldn't have any play - only pivoting movement. Does the outboard joint move with the shaft, or is the play between the shaft and joint?
Old Jun 9, 2026 | 01:31 AM
fibrepunk's Avatar
If you haven't found the issue. It is the CV axles.
1. You will get the vibration when the car is under acceleration
2. When you are not accelerating - no vibration
Old Jun 10, 2026 | 01:24 PM
MrDucky's Avatar
When I get shuddering when accelerating at low RPMs I clean the throttle body and it fixes the problem.
Here is a video that shows process. You will have to remove the air box to get access. Use the throttle body cleaning spray.
Old Jun 10, 2026 | 01:49 PM
FitFun1979's Avatar
You sure about that?
At that mileage, as long as the boots are fine, there shouldn't be any issues with the CV's.
I have CV axels on my BMW dating back to the Reagan era that have never been apart and operate like new.
Old Jun 10, 2026 | 03:08 PM
fibrepunk's Avatar
Regardless of the boots on the CV axles, if and only during accelation that your car vibrates, it is most likely the CV axles. I had an Accord that had no grease leaking nor CV boot damage, but would shake/vibrate when I accelerated between 50-60 mph. Replaced the CV axles fixed the issue. Again, only happened during acceleration between certain MPH, so whenever you experience vibration to the car/steering wheel only during acceleration, go get the CV axles replaced.
ObeseCheetah
Feb 7, 2025 01:30 PM
TotallyDoesn'tLikeKids
Jul 19, 2024 05:47 AM
RedRobin473
Mar 12, 2024 09:11 AM
robbbbb
Feb 20, 2024 04:04 PM
dirtybird222
Aug 30, 2016 11:37 AM
