Android and the Fit
Old Jun 21, 2014 | 01:21 AM
Rekrab's Avatar
Android and the Fit
I'm getting ready to pull the trigger on an EX-L, only thing that's giving me some pause is that I haven't seen much talk about how well the infotainment system works with Android phones, if at all.
Any owners had some experience with them yet?
Old Jun 21, 2014 | 01:57 AM
JediPat's Avatar
The bluetooth feature works fine on my Note 3, Pandora plays just fine also. The features we don't get YET are access to the HDMI port for the on screen nav from our phones and whatever other features it allows us.
Old Jun 21, 2014 | 02:03 AM
Rekrab's Avatar
Ah, well that's not too bad. Thanks for the info. I had read that Honda is planning Android integration by the end of the year. Until then I certainly don't mind using my phone (Galaxy S4) for my navigation.
Old Jun 21, 2014 | 10:36 AM
A41Billy's Avatar
I also have a Note 3 and all BT functionality works. I bought an MHL adapter and have mirrored my phone to the deck with Google Maps. It works, but you cant listen to music while thats on, so that negated the deal for me.
Old Jun 21, 2014 | 12:56 PM
theindiearmy's Avatar
Does the HDMI not retrieve audio as well? I imagine it does if you can play movies off of it. So what does it do if you're playing music while running Google Navigation? I don't imagine the Honda has the ability to tell your Android Music app to stop playing. That doesn't seem right.
Old Jun 21, 2014 | 01:28 PM
tmfit's Avatar
The hdmi port will only allow the nav app to work while the car is in gear. When in park it will allow the playing of movies. With the nav app it will just put the music in the background while giving directions and if you use siri for verbal directions the dame thing happens
Old Jun 21, 2014 | 01:33 PM
So then you can play music? It will just give the navigation commands priority when they play, which is how Android works anyway.
Old Jun 21, 2014 | 05:00 PM
A41Billy's Avatar
I was speaking about the source being used by HDMI. I am sure I could stream music simultaneously while maps is up. I just cant play music off USB drive or radio while using HDMI. First world problems lol.
Old Jun 21, 2014 | 06:01 PM
tmfit's Avatar
That is correct.
Old Jun 22, 2014 | 02:03 PM
mecevans's Avatar
I'm sure someone can hack either the head unit of the app to work around this.
Old Jun 23, 2014 | 01:59 AM
jdhommert's Avatar
Explain this to me please. I'm an Android nerd but I dont know much about MHL, and don't know anything about the Fits yet. Trying to learn. The lack of Android support for Hondalink is a major hangup for me. Worried that if I would buy one, they couldnt update my car to be Android friendly.
Anywho- So you can buy an adapter to plug into your phon eand it will mirror the display or app? That works with the current 2015 Fits? Hard to install, or does it work via the USB port I'd assume?
I'd do a happy dance if I could get Google Maps on my display.
I'd buy you a beer if I could get hangouts and movies etc on my display on the current cars with just an adapter.
Old Jun 23, 2014 | 09:03 AM
BMO's Avatar
BMO
Originally Posted by jdhommert
Anywho- So you can buy an adapter to plug into your phon eand it will mirror the display or app? That works with the current 2015 Fits? Hard to install, or does it work via the USB port I'd assume?:
To mirror, you just need a micro-USB to MHL adapter like this: Robot Check
I'm going to investigate this one to see if I can charge at the same time as mirror: Amazon.com: Cable Matters Micro-USB to HDMI MHL Cable in Black 6 Feet (NOT Compatible with Galaxy S3/S4/Note2/Note3): Electronics
I have a MotoX and most listings on amazon are geared towards the Samsung Galaxys, so we'll see how that pans out. I will just have to wait 'til the car comes in to test it out!
Old Jun 23, 2014 | 09:12 AM
BMO's Avatar
BMO
On a similar note: If anyone's feeling particularly adventurous, you could try a Raspberry Pi setup in the glovebox. That way you could run whatever you want on the screen. I might investigate making it into a wifi hotspot, which is total overkill, but would be awesome!
Running Raspberry Pi natively in a Honda Civic? Oh, the possibilities! | TechnologyTell
Old Jun 23, 2014 | 10:09 AM
mecevans's Avatar
I don't think the MotoX supports MHL, only Miracast. I have this one..
https://www.amazon.com/dp/B00904JILO/ref=cm_sw_r_udp_awd_2sdQtb0Q1VJ63P85
Streams straight to the box no WiFi needed.
Old Jun 23, 2014 | 10:16 AM
BMO's Avatar
BMO
Ugh, you are right! Thanks for saving me some money and frustration. There was some conflicting info re: MotoX and MHL from Republic Wireless
I have an (old for tablets) Toshiba Thrive with full-size HDMI out, so will probably just use that (or Raspberry Pi if I get crazy).
Old Jun 23, 2014 | 11:00 AM
SUNNYboi's Avatar
Galaxy S5 here and everything works fine! Even then text messages get read to me.
Now I had a S4 a couple of days ago and the only thing that didn't work was the text read back feature. Other then that, everything else was flawless.
Old Jun 23, 2014 | 07:28 PM
jdhommert's Avatar
People are talking about using MHL to mirror the display. But I thought it wouldnt display HDMI or whatever unless the car was in park?
Can you tell me what "everything" is? I'm really trying to figure out as of right now what I can do with my Android phone. It says it is MHL compatible (One M8)
Old Jun 23, 2014 | 07:39 PM
ntx's Avatar
ntx
Yup he is right. I pulled mine off the tv and took it outside to the car. Google maps when parked just the sound when driving.
Old Jun 23, 2014 | 07:46 PM
jdhommert's Avatar
Gotta find a way to enable HDMI when driving!!!!
Old Jun 26, 2014 | 04:22 PM
chrisjones's Avatar
I've hoped for the same thing -- to use the display for Google Maps (navigation) while driving in order to need neither my dash-top Garmin (awkward to use in this car) nor the smaller screen on my phone which isn't easy to position well anyway. I've had the same problem with the screen input from HDMI not working when the car is in gear. Even if I could solve that problem, I could never get the sound from HDMI to work because I simultaneously have the phone paired via Bluetooth in order to take calls and such over the built-in system. Android wants to route *all* sound through Bluetooth if it has a live connection, and while HDMI is enabled on the car, it isn't playing the sound that is being routed over Bluetooth.
So I have TWO Problems to solve -- over-riding the inability to do HDMI while the car is moving, and the sound wanting to go over Bluetooth instead of HDMI without breaking the pairing.
