Pictures of Modifications in Progress
Old Aug 9, 2014 | 06:13 PM
SilverEX15's Avatar
Let's see if I can post pictures from Imgur.
I ran a wire from the engine compartment into the car, That will power a separate fuse block that will power several other things. I used a chopstick to poke through a grommet on the passenger's side. you can see the wire in the engine compartment and then inside the car.
I put these door handle protectors on all four doors. They are magnetized, so they come off easily - from Amazon.
I found a good spot for my XM radio, with the wire sneaking down inside the paneling. I removed the door gasket to get it back there.
http://imgur.com/2xbw7IA,wgHDQCU,Zj6...s8gb,yQJ0Cmy#0
imgur: the simple image sharer
http://imgur.com/2xbw7IA,wgHDQCU,Zj6...s8gb,yQJ0Cmy#2
http://imgur.com/2xbw7IA,wgHDQCU,Zj6...s8gb,yQJ0Cmy#3
Old Aug 9, 2014 | 06:38 PM
Avus's Avatar
open up your image on the screen in imgur and right click the image and copy its location. Make sure this is on the largest version you have. once that is copied past it with in tags that look like this.
[img]*pasted portion*[/img]
the imgur page has these listed to the right of your photo. Just copy and paste it.
Old Aug 9, 2014 | 06:47 PM
BLXFITTY's Avatar
there is also a list of copy and paste links to the right just copy and paste the pics for FORUM links
Old Aug 10, 2014 | 06:51 AM
SilverEX15's Avatar
Old Aug 10, 2014 | 06:53 AM
SilverEX15's Avatar
Old Aug 10, 2014 | 06:58 AM
Black3sr's Avatar
Right click on pic in your album. Then click on Image location. Go back to Forum and click on the little yellow icon at the top of message posting area. Then paste the link.
Old Aug 10, 2014 | 06:59 AM
SilverEX15's Avatar
Old Aug 10, 2014 | 07:01 AM
SilverEX15's Avatar
Okay. Got it. I have to add [img] before the link and [/img] after the link.
Old Aug 10, 2014 | 07:35 AM
Black3sr's Avatar
It should be there when you copy. This is one I did from using Photobucket to store my pics. This is what I copied from there -
http://i90.photobucket.com/albums/k2...FIT/004-15.jpg. I pasted this in the window that comes up when you click onthe little yellow mountain
Old Aug 10, 2014 | 08:06 AM
SilverEX15's Avatar
https://i.imgur.com/yQJ0Cmy.jpg
I copied the URL, and no pic appeared.
Old Aug 10, 2014 | 08:09 AM
SilverEX15's Avatar
Little yellow mountain?
Old Aug 10, 2014 | 11:13 AM
SheepNutz's Avatar
What you need to do is click the little yellow picture icon, then paste your link there and it'll automatically add the img and /img code. I have circled it in red below:
Old Aug 10, 2014 | 11:47 PM
TofuShop's Avatar
which XM unit do you have? i have the free Stratus 7 model and it sucks. i can barely get reception and the sound quality is crappy
Old Aug 11, 2014 | 07:05 AM
SilverEX15's Avatar
I have a couple of Roadys, but since I would be transferring a Lifetime subscription from my Cube, I wanted a new radio. I got the Onyx. I have the antenna on the dash, and it works okay. I didn't feel like tearing everything up to just it on the roof.
I had the antenna on the dash of the Cube, and it worked fine there.
Old Aug 12, 2014 | 12:36 PM
TofuShop's Avatar
I have my antenna on the dash as well, but I usually have 2, if im lucky 3 bars of reception. but sound quality is really low
Old Aug 12, 2014 | 01:26 PM
SilverEX15's Avatar
What program did you use to make the red circle?
Old Aug 12, 2014 | 11:05 PM
SheepNutz's Avatar
Microsoft paint.
Old Aug 13, 2014 | 05:34 AM
tmfit's Avatar
I also bought the Oynx but put the antenna right behind the radio antenna, other than the wire coming in the hatch . I tucked the wire in behind the trim along the ceiling all the way up front then down the trim and under the dash. Was easy and took about 5 minutes. Having said that the dash is still easier.
Old Aug 13, 2014 | 07:08 AM
SilverEX15's Avatar
Good idea. I never thought of putting it behind the headliner. I've always run wires under the lower part of the car.
By the way, the power wire for the Onyx is not very strong. I caught my foot on it as I was getting out of the car yesterday, and it broke. It wasn't connected, since I still have everything apart. Looking on Amazon for a new one, I read quite a few negative comments about the SiriusXM product, so I got a different replacement.
Robot Check Robot Check
The Onyx power cord doesn't have two wires side by side. One wire is in the center, with the other one surrounding it. Since it is so thin to begin with, cutting, stripping, and joining doesn't seem to be practical. The new one will arrive today. There's no plug, just two wires to connect to power.
I have a cord from a Roady, but that puts out 6 volts, and the Onyx cord puts out 5, so I didn't want to take a chance and use that one.
feddup
Jun 27, 2020 09:36 AM
noripwr
Oct 21, 2014 06:48 PM
krissnkev
Jun 6, 2008 04:18 PM
madchemist
Apr 23, 2007 05:25 PM
kentris
Jan 8, 2007 08:45 AM
