Triple 12 Volt Outlets
Old Aug 11, 2014 | 02:40 PM
SilverEX15's Avatar
I found the perfect way to power three 12 volt devices. I bought a triple 12 volt outlet at Radio Shack for $20. It comes with both a plug-in connector and a wire with a fuse. I'll tap into the wire for the 12v outlet and tuck the triple outlet under the dash. I have an XM radio, GPS, and dashcam that I'll plug into it. I'm pretty sure the XM radio wants to use the plug that came with it, rather than just running off 12 volts. Unless they've changed since Roady days, the radio runs on 6 volts, and the plug does the reduction from 12 to 6 volts. It appears that the center outlet will light up when it has power.
Old Aug 11, 2014 | 03:28 PM
simonx314's Avatar
Sounds cool. Let us know how it goes and keep the pictures coming.
Old Aug 11, 2014 | 04:10 PM
SilverEX15's Avatar
Will do. I'm putting up gutters and cleaning out the garage at the same time, so everything is taking longer than it should. When it comes to projects on a car, I like to take my time and think it through.
Crawly
Mar 15, 2020 02:35 AM
everitta
Dec 27, 2018 01:23 AM
crash1st
Feb 28, 2016 12:34 AM
hellgiver
Sep 10, 2014 09:26 AM
Crawly
Sep 12, 2007 09:41 AM
