Update on Connector Behind Outlets
Old Aug 14, 2014 | 08:23 AM
SilverEX15's Avatar
I mentioned the other day that while I had the panel with the 12v/HDMI/USB outlets removed, I was unable to lock or unlock the car using the door handles.
Now I found a new reason for that connection: the car won't start without it. I had been leaving that panel disconnected while I messed around in there, deciding what accessories should go where. When I want to drive the car, I have to plug in that cable. It's the one on the bracket over the three outlets.
Old Aug 14, 2014 | 09:03 AM
noripwr's Avatar
I believe that actually goes to the LED module.
Old Aug 14, 2014 | 09:06 AM
BrassInTheGrass's Avatar
Can you investigate that LED there? Can it be replaced to match the Blue Interrior illumination?
Old Aug 14, 2014 | 10:06 AM
SilverEX15's Avatar
Which LED is that? What does it do - aside from looking pretty?
Old Aug 14, 2014 | 10:30 AM
noripwr's Avatar
Personally I'd rather replace the led in my interior illumination kit with soft white to match the ones there in the center console. I suppose it requires some soldering.
KayakPaddler
May 22, 2017 12:39 AM
Shipoffools
Mar 12, 2017 09:59 AM
markakis3100
Mar 25, 2016 01:50 PM
SilverEX15
Aug 11, 2014 05:45 PM
xko
Feb 2, 2011 02:20 AM
