Wheel spacers
Old Nov 17, 2017 | 02:13 PM
hasdrubal's Avatar
I had an old E30 318 with some really awful pot metal spacers on it. They were 5mm, but so many holes for lightening that one day one of them cracked so bad the pieces fell out, causing a wheel to wobble a few times and then depart the car at about 30mph. Turned out the previous owner who put them on hadn't cared for more than about two or three turns worth of thread engagement.
On the other hand, when I got some longer studs and some solid spacers (had to, the wheels that came with the car rubbed against the strut without them), I never had a problem. I think if you use quality parts, it should be fine. And in the rear, there really isn't that much weight in the first place, so any added stress on the bearings should be less of a deal.
Old Nov 17, 2017 | 03:07 PM
ashchuckton's Avatar
Good points about using longer studs & quality spacers if you plan to go that route.
Old Nov 18, 2017 | 06:01 PM
Originally Posted by knope
Imagine in your head a battleship sitting in the water as the car. Take note how the sides of the battle ship slant outward from the center as it moves away from the water (road). The look many car people go for is the opposite, the closer you get to a turtle (wider stance) the less like a battleship the car will look.
lets use negative and positive camber vs battleship and turtles.. im like wtf u talking about? lol
"dood check out dat hella-turtle."
haha
Old Nov 18, 2017 | 08:43 PM
hasdrubal's Avatar
Could be worse, some warships have flare (wider above the waterline), and some have tumblehome (narrower above the waterline). So instead we could say "man, that car is all DDG-51, they should get some spacers and make it more DDG-1000."
Old Mar 9, 2018 | 02:39 PM
wamasan's Avatar
Link to spacers
Originally Posted by figmk5
Figured I would post a shot of my Fit with newly installed spacers. Fantastic improvement in looks in my opinion, from such a slight change!
do you have a link to these spacers?
Old Mar 15, 2018 | 07:06 PM
knope's Avatar
Talking
haha
i dream that one day my car will have all the wide-turtle-feet and 0 camber with hella-flush fender arches.
Old Mar 20, 2018 | 02:51 AM
wamasan's Avatar
Before/After 25mm spacers install
25mm rear hubcentric spacers installed on completely stock 2015.
Razzer
Jul 19, 2013 05:26 PM
MNfit
Oct 25, 2010 10:43 PM
MIAMIFIT
Apr 6, 2010 01:06 AM
prossett
Mar 14, 2008 01:29 PM
heymikesays
Oct 25, 2006 09:50 AM
