Radio stereo head unit
Old Aug 20, 2014 | 02:10 PM
mc1200s's Avatar
Ladies and Gentlemen,
I'm listening to music while pulling into the garage and and I push the blending start stop to turn off the car and it always kills my music. Hiw do I prevent this? It's incredibly frustrating to have to turn the power on again as it interups the mood. How do I maintain audio during an on off cycle thanks.
Old Aug 20, 2014 | 02:33 PM
simonx314's Avatar
I would also like to be able to shutoff the engine without interrupting audio. To prevent wasting fuel while idling, I turn off the car then turn the stereo back on but I miss several seconds of news radio which makes the news hard to follow. I looked over the manual and there does not seem to be a way to turn off the engine without also turning off the audio.
However, if you turn off the car while in neutral, the car will stay on until you shift into park. I can't remember if this shuts off the engine or not, but if it does, then shifting into neutral first would be a workaround.
Old Aug 20, 2014 | 02:58 PM
you dont. just keep the engine running or just kill the mood. your battery is tiny dont drain it.
Old Aug 20, 2014 | 03:04 PM
simonx314's Avatar
Listening to the end of a song isn't going to kill the battery. Filling the garage with fumes is going to kill the brain cells.
This is one of the problems with push button ignition. In traditional cars I can turn the key back to the accessory position to stop the engine without interrupting music.
Old Aug 20, 2014 | 03:17 PM
tommycrx's Avatar
Humming the end of the song would not drain the battery.
Old Aug 20, 2014 | 03:59 PM
mc1200s's Avatar
Poor response.
Old Aug 20, 2014 | 04:07 PM
tmfit's Avatar
Doubt there is any easy way to prevent it. You may be able to track down the feed wires and connect them to an always hot line but make sure you never leave the radio on once you get out because as said, they are tiny batteries and I ran mine down while installing Sirius while working with tech.
Old Aug 20, 2014 | 05:51 PM
SheepNutz's Avatar
I think he's saying that constantly stopping and starting your car is what's going to kill the battery.
Old Aug 21, 2014 | 12:49 AM
quikser's Avatar
I believe leaving it in ANY gear (or neutral) and turning it off leaves the power on (and the audio)... Shifting to park ultimately turns the electronics off. A little different than the Accord EX-L I had, (I think on that one you held the shift lever button in and pressed the start button to go back to the accessory mode)
Going off memory as I haven't driven the car in a few days but I think that's how it works... Will confirm on next drive unless someone beats me to it.
Old Aug 21, 2014 | 08:45 PM
simonx314's Avatar
I can confirm that if you turn off the car while in any gear other than park, all accessories will remain powered, but the engine will shut off. This work-around is a solution that allows us to both turn off the engine but not interrupt listening to the rest of a song.
Old Aug 21, 2014 | 11:24 PM
SheepNutz's Avatar
What about those of us with a manual transmission? I may need to test this out soon.
Mister Coffee
Sep 12, 2018 10:52 AM
A2Fit
Mar 5, 2015 08:19 PM
jojonyc
May 13, 2014 09:47 PM
graphixgurl
Feb 4, 2014 03:34 PM
dickiez
Apr 4, 2010 12:09 AM
