Good News About Fuses
Old Aug 31, 2014 | 08:59 AM
SilverEX15's Avatar
You might have noticed that the fuse boxes have several empty slots. I wondered if they had power. I tried it with the ignition turned one, and most of them do. I got one of these add-a-fuse things from Amazon,
Amazon.com: Pico 0956PT 10 Amp ATM Mini Blade Fuse Add-A-Circuit Fuse Holder: Automotive Amazon.com: Pico 0956PT 10 Amp ATM Mini Blade Fuse Add-A-Circuit Fuse Holder: Automotive
and, using a test light, I plugged it into several empty slots under the dash. Most of them lit the light. It was tricky getting the adapter plugged in, though, probably since the fuses are so deep into the box.
This means that you can add a circuit without doubling up on another circuit. The same applies to the box under the bood, so that's an easy way to add a circuit.
Old Aug 31, 2014 | 09:25 AM
rodney's Avatar
SilverEX15
Jul 30, 2015 03:30 PM
SilverEX15
Jul 24, 2015 09:14 AM
oneder101
Jun 15, 2015 05:03 AM
SilverEX15
Aug 30, 2014 09:54 PM
ratedz
Jan 6, 2009 08:54 AM
