Replacing Front speakers and Tweeter
Old Sep 26, 2014 | 06:56 PM
robmorenofit's Avatar
Hi Folks,
I will be replacing my front two speakers and tweeters and adding an amplifier to start, then maybe finish the back two and add a sub later if I need it. Has anyone upgraded their system yet? Is it straight forward? How do you get to the tweeters? Thanks dudes!
Old Sep 29, 2014 | 02:27 AM
nicco's Avatar
If you hunt thru the posts you can find some good pics of the stripped interior.
I am planning to replace the speakers and add an amp and sub so have been looking for space to do so. I don't have the tweeters on my VTI so will go with coax speakers over splits to get the better grade for the same $. I am just about settled on attaching the amp to the rear seat stands so it is out of the way.
I peeled away the left trunk skin for a look the other day, looks like there are some good mounting points to secure a sub and a factory earth if you wanted to put an amp there. I am going to probably spray some sound deadener up onto the quarter and then make a fibre glass sub enclosure to squeeze a 10 inch shallow mount in there without disrupting the access to the spare.
Not sure about using the top of the shock absorber as a mounting point but there is a good inch of thread there.
Brentw101
Sep 6, 2018 03:55 PM
magdalena
May 15, 2012 07:21 PM
Coppatop85
May 3, 2011 09:05 AM
zakurie
Dec 7, 2008 12:33 AM
jaebee
Aug 31, 2008 08:17 PM
