Is coasting downhill with the engine OFF harmful to the drivetrain?
Yep. When I was driving the Tahoe rental it had a V8 engine so when going on fairly flat road the display would report which mode the engine was running at: V4 or V8 so it was going V4 most of the time. It changes mode automatically depending on power needs. Pretty cool way to save fuel.
Virtually every EFI system turns off the injectors when the manifold pressure is low, the throttle closed, and the RPMs significantly above idle. If they didn't do this emissions would go up as the mixture wouldn't burn effectively.
YOU ARE CORRECT.
I took our 2011 Fit down to the gas station tonight. From 40 mph I left off of the gas and it did not return to an idle rpm. I coasted for two blocks slightly down hill and it did not return, so it is indeed slightly engine braking.
I was wrong on my previous statements as they pertain to the Honda Fit.
The wheel shouldn't lock with the key in ACC position...
BUT
Still an unnecessary thing to do, and I think bad for the CVT, since no pumps are running. I also think you only have emergency brakes, one or two powered pumps before you lose vacuum. Like has been said, the injectors shut off when coasting with no throttle anyway.
Also generally illegal.
BUT
hydrogennine
Sep 7, 2011 11:59 PM
pastafarian
Apr 17, 2008 11:10 AM
