Generator Shed
Old Nov 23, 2014 | 09:10 AM
SilverEX15's Avatar
Generator Shed
I realize "Generators" isn't a topic normally covered on this forum, but you asked for it.
A couple of days ago, some of you asked me to post pictures of the shed I built to cover my generator to protect it from the weather and to muffle the noise. I did a lot of online reading, but if I had it to do over again, I would have made it larger.
I used 3/4" plywood and 2 x 3's, with insulation in between the double walls. For the axle, I used a steel rod from Lowe's. I had to get a couple of different wheels till I got something large enough and strong enough. This shed is very heavy. I made a door/cover for the front, but it quickly got too hot inside, so I never use it. I have an indoor/outdoor thermometer, so I can keep track of the temperature inside the shed. If it gets too hot, I wheel the gen out a bit.
The exhaust was tricky because it gets very hot very quickly. Also, I have to start the generator before wheeling it into the shed and then attach exhaust. If I were to do it again, I would make the hole in the side of the shed larger. That flexible tube fits through the hole in the side of the shed, and then I put a rigid pipe over that, with an elbow angled down.
The large elbow in the rear is for an exhaust fan which I plug into the generator. It helps to pull out some of the hot air. The front wheels are castors, but I'll install larger ones to make it easier to maneuver.
Old Nov 23, 2014 | 10:00 AM
stembridge's Avatar
Nice! Scale it up, and it would make a nice Fit garage... (c:
es
Old Nov 23, 2014 | 10:08 AM
Bassguitarist1985's Avatar
Im a Generac technician, and frequent smokstak.com and zillerelectric.com. if you ever need assistance with repairs im in the know. Both portable and stationary standby units, air cooled models mostly.
You need a fan forcing outside air into the shed with an exhaust port separate from the engine exhaust. Many guys will install a thermal switch to shut down the engine when it gets too hot inside.
Hope the suggestions help. I share my big 7k generator with the neighbors run their fridges during an outage, so they look the other way because of the noise. Maybe at some point I'll make a shed like yours.
Cheers
Bass
Old Nov 23, 2014 | 12:13 PM
SilverEX15's Avatar
Cheers
Bass
Thanks for the comments. If I had to make another one, I'd make it larger, but this one cost about $350, so I think it will be my last.
Old Nov 23, 2014 | 09:25 PM
DrewE's Avatar
If you enlarge the hole in the side for the exhaust output to the size of the stovepipe, and keep the tube centered in the stovepipe, the flow of exhaust will pull some air through the larger pipe and help keep it cooler. (I think I'm reading what you did properly...if this is actually what you have set up, rather than the hole tight around the flex pipe, then obviously ignore the comment.) Also, if you direct the pipe up and add a few sections of stovepipe, above head level, a lot of the noise will be directed upwards rather than bouncing off the ground.
A commercial product for RVs that operates on this principle is sold as the gen-turi.
Overall, nice work, and plenty strong so that it's not going to collapse.
Old Nov 24, 2014 | 01:04 AM
Vanguard's Avatar
Great concept, and great pictures. I never considered the heat issue. It looks solid. I bet it is very heavy. Is the generator a manual (pull) start, or an electric start? The insulation you used between the walls, is it fiberglass or is that blue board an insulation product?
One time we built a workshop on our factory floor, because the machinery was deafening to the workers sharing the space. We used pegboard over fiberglass insulation on the inside surface of the room (walls and ceiling), to help absorb the sound, which it did very well. I could see it cutting the weight down as well.
We joked in another post that it looked as though you had taken the pictures on your roof. I wonder if you could not install an active, or even powered ventilation fan on the roof of your project, in order to eliminate the heat build up.
Anyway, you have inspired me to purchase a generator, and solved the problem I had with where to locate it, so carbon dioxide did not creep into the house.
Thanks again for the pictures! They are great!
Old Nov 24, 2014 | 07:46 AM
SilverEX15's Avatar
I didn't show the stovepipe that is a tight fit in that hole. I had to use the flexible pipe to get it connected once the gen was in the shed and running. Lots of noise, vibration, and heat.
I like the idea of a tall, vertical pipe. It would have to be permanently attached to the shed.
Old Nov 24, 2014 | 07:53 AM
SilverEX15's Avatar
The generator is pull-start, so I have to start it and then get it inside the shed. Then I have to connect the exhaust. The insulation is the blue board. I have the exhaust fan on the rear of the shed, so I'm not going to add another. There's a trade-off between sealing the noise in and making holes that will let it out.
I've had this generator since 2003, and it cost just $703. It included a "rebate," which was the panel that connects it to the breaker panel in the house. It's a nuisance getting it hooked up when the power goes off, but it's great to have light and water during a power failure. It uses a lot of gas, though, so if you get one, keep several 5 gal cans of gas on hand - with Sta-Bil in the gas.
Old Nov 24, 2014 | 08:20 AM
Vanguard's Avatar
I have a reserve of 35 gallons of gas, in metal 5-gallon tanks, on hand at all times. I try and fill them when gas is trending cheap, as it is now, then use the gas when prices rise. I also keep Sta-Bil in each tank. To date, I have never had any gas go bad (knock on wood). I picked 35 gallons because that is what it would take to fill all our cars once. I guess it is the "prepper" in me.
I have my eye on a generator with electric start, and a Honda engine. Sam's is selling it now, but I am thinking of waiting until after the holidays to purchase it. I am still debating the electric start. as it add's the variable of maintaining the battery to the equation.
I will be using a variation of your shed however, and appreciate your posting that information.
Old Nov 24, 2014 | 12:09 PM
SilverEX15's Avatar
After sitting for months, mine starts on the first or second pull. A new battery will cost almost $100, and you will have to remember to keep it charged.
Old Nov 24, 2014 | 12:29 PM
GeorgeL's Avatar
For ventilation, all you need do is run a large duct to the cooling air inlet around the magneto from outside the box. This makes sure that cold air is used to cool the generator and all you need to do is vent the box on the far end for the air to get out. No need for an electric fan that way and as long as the generator is running it will get cool air.
Old Nov 24, 2014 | 02:30 PM
SilverEX15's Avatar
Clever. I'll have to look into that.
Old Nov 26, 2014 | 12:03 AM
GeorgeL's Avatar
Not really my idea as the type III and IV VWs worked that way. Duct air from a remote cold source to the cooling inlet and it simplifies a lot of issues.
Old Nov 26, 2014 | 07:40 AM
SilverEX15's Avatar
If I had a couple of thousand extra dollars and lots of free time, I'd build another shed.
Here's an idea. Buy one of those ready-made storage sheds and get a long-enough cable to plug into your house. It would be expensive, but quiet, and you could walk right into it to start it and refill the tank.
Old Nov 26, 2014 | 11:36 AM
You guys should look into a tri fuel conversion kit from US carb. As you know, gasoline does not store well, but propane and natural gas do. Granted they have less BTUs but are a great alternative for storage. I have a 100 pound propane tank that I have for the grill and 7k generator.
here is my conversion. Its a loud Generac, but puts out good power for my needs. 7k on gasoline, I'd say max around 5800-6k on propane/natural gas
Old Nov 26, 2014 | 11:44 AM
SilverEX15's Avatar
"here is my conversion." Is there supposed to be a link there?
Old Nov 26, 2014 | 07:15 PM
DArkk's Avatar
I have seen this type of fuel conversion before and it's great for emergencies provided you have large tanks. However, it cost more to run on propane or LP gas than regular gasoline due to lower energy output.
Honda tried with this for the NGV variation. I've seen a few of em around here but on full tank it only provides around 200 mile range. Trunk space? Forget it. Fine for daily commute and the convenience of refilling at the house.
Old Nov 26, 2014 | 11:24 PM
My bad, here is the link. Propane and Natural Gas Generator Conversion Kits - Motor Snorkel
Old Nov 26, 2014 | 11:26 PM
Correct, these fuels are not meant to replace gasoline, but are an alternative when gasoline are in low supply, especially after hurricanes, storms, etc. Hurricane Irene and Sandy, gas stations were either out of gas no had no electricity to pump it. whats a prepper to do? Have an alternative fuel source until gasoline was available.
Old Nov 27, 2014 | 02:58 AM
DArkk's Avatar
Yep, I've lived in Florida for 20 years and had the unfortunate aftermath experience of the hurricanes in 2005 and 2006. My entire neighborhood lost power for two weeks and during that time gas stations couldn't provide fuel because no electricity to run the pumps! Until power was restored they put entire southern state under nightly curfew!
Let me tell you something after being whacked with three hurricanes back to back the same year (I was in West Palm Beach, Fla at the time) it transported the entire southern Florida back in time where electricity was unheard of. Imagine walking into the supermarket only to find few items on the shelves and nothing in the fridge / freezers it seriously made me feel like I was in third world country.
So yeah always prepare for the worst. Lucky I stocked up on canned foods from Costco before the hurricane season. Two weeks of clam chowder kept me in check. lol
