Dead battery problem
Old Feb 6, 2015 | 08:44 PM
ROTTBOY's Avatar
Originally Posted by BillyJack
...........don't disconnect the terminals without having your radio code handy, as the radio will lock up once power is disconnected...............
Just to confirm that BillyJack is correct. Been there, done that. Get that radio code prior and write it down somewhere.
Old Feb 6, 2015 | 10:44 PM
mahout's Avatar
Originally Posted by oaf
Well, I can unlock the doors using the remote but after that, nothing else really works. The overhead lights does not work, it cannot lock the car using the keys again.
It happened again tonight. After one hour waiting, I had to call Road Service to jump start my car. I drove back home (around 20-25 minutes) and locked my car. Few minutes later, I unlocked my car, tried to turn the engine on, but only the panel lighted up for a sec and now, not even the locks work.
I will try to get a multimeter to measure the battery and I'll call the dealer again.
the multimeter isn't likely to be a help. you need to have a battery load test at most aftermarket car parts counters for free.
but it sounds more like a bad connection between the starter and battery or bad starter solenoid. the dealer will see that only if it fails and momentary not that easy unless its a bad connection, which will certainly be an intermittent problem. my guess its at the starter rather than solenoid if its not the solenoid. you can check the connections at the starter yourself; if the connector wiggles tighten it.
good luck.
one would think the dealer would have found that but they probably only hooked OBD II tester and didn't see anything - guess why.
Old Feb 7, 2015 | 05:44 AM
n9cv's Avatar
Be careful with some of those load testers. I had an occasion to take a battery in for warranty and the guy said "when did you buy this battery?". I gave him the date and the test came back that the battery was good. I looked at the tester and said how can you load test with a tester that has those thin cables? I had him rerun the test only I subtracted 3 years for the sale date and the thing now said that the battery was bad. We ran the test a total of 5 times each with a different install date and determined that the results were based on installation date and battery voltage, not an actual load test. So some places the tester that they use is not an actual load test at all. I turned the headlights on for about 20 minutes and ran the battery down Then had him run the test again. It finally failed so he had a print out that said it was bad with the correct date. I got a new warranty battery.
I'm not saying all places are like this but some sure are.
Old Feb 8, 2015 | 06:42 PM
FitIam's Avatar
Defective battery replaced by dealer
Originally Posted by GotFitB13
A few other members and me have had some battery problems, although I think closer to taking delivery of the vehicle. I suggest having the dealer check it and if they deem it necessity to replace the battery then you should be all set. Otherwise they can check your connections too.
There was a similar thread about some defective 2015 Fit batteries. My battery failed 3 times and finally, I was able to get the dealer to replace the battery. Since then, I haven't had any problems (knock on wood) with the battery despite even colder Chicago winter temperatures.
One time I left the driver's overhead light on, so I'm also very careful to make sure that I don't leave any overhead lights on when I shut off and lock the car.
Old Feb 8, 2015 | 08:59 PM
GotFitB13's Avatar
Same here. No problems since the battery was replaced. I run a subwoofer and Scangauge. I'm just a bit south of you FitIam. Do you ever notice your engine revving on the real cold days shifting into drive (if you have a CVT)?
Calvincito
Dec 20, 2024 01:16 AM
pzriddle
Jan 23, 2015 06:31 PM
hogwylde
May 27, 2013 06:18 PM
N.O.R.M
Mar 31, 2013 12:23 AM
d_cymbal@hotmail.com
Aug 28, 2005 11:31 AM
