Looks like C&D is EH about the 3rd gen long term test so far.
Old Mar 13, 2015 | 03:35 PM
GeorgeL's Avatar
If you can accurately shift at redline with the tach winding up fast in first gear at WOT you're The Stig on Adderall. Mere mortals will err by 500RPM or so, preferably on the low side!
99% of drivers don't get near redline in normal driving.
Old Mar 13, 2015 | 03:51 PM
Wanderer.'s Avatar
Originally Posted by Fitmo
Lemme help you with the arithmetic. At the 6,800 rpm redline, it's 3,844 rpm, or about 1,000 rpm below the GE 4,800 rpm torque peak. Not a lot better than the GK which has a lower torque peak. Even if you bang it off the rev limiter at 7,000, you're at 3,957 in second at best--1,000 rpm below your 5,000 dream. [edit] If you're really seeing 5,000, your clutch is slipping pretty badly when you hit second.
You may be right, i'm going to try it later today. I know 2-3 is better than 1-2, maybe that's what i'm thinking of. I'm pretty sure I end up north of 4k for sure but I am curious now but i'm not afraid to admit when i'm wrong
Yes I know, the math shows it but I will try anyway. There may be some clutch slippage like you said, but I don't think so because it will still chirp the tires.
So I am a 1%er
You can just glance at the tach when you know you're close. It's just a Fit, it doesn't accelerate that fast. Or just tag the limiter.
Old Mar 13, 2015 | 03:59 PM
Fitmo's Avatar
I was pretty good at just kissing 8,000 if shooting for the 7,800 rpm redline on my GS-R. The limiter was 8,200 and I hit it more than once though.
It was a lot more embarrassing with a carbed setup where the ignition started skipping every other firing on each cylinder at the limit. Lots of popping in the exhaust!
Old Mar 14, 2015 | 12:09 AM
Desmond Lamar MacRae's Avatar
The only thing I really agree with about the review is to get the EX over the LX--no question.
As George L once astutely pointed out, if these auto journalists have to downshift from top gear while climbing a grade or passing, they say the car is gutless. So instead of putting a sixth gear above the GE's fifth, where it was actually needed, Honda put it between the GE's 4th and 5th, which was already about perfectly spaced, and where it just gets in the way. And it still screams along at almost 4,000 rpm at 75 mph compared to the CVT's relaxed 2,500 rpm.
The Fit's manual ratios are probably the most poorly chosen ones I've ever seen. First gear is almost a granny gear and there's a huge drop between it and second gear. You can run 1st to almost 7,000 rpm and when you hit second, you're still about 1,000 rpm below the torque peak. It's way too widely spaced down low and way to closely spaced up top.
So Honda produces a six-speed for the car reviewers and a damned sporty CVT for the rest of us.
Thats very interesting. Honda usually does gearing of manual so if you shift right b4 fuel cut-off, the engine will stay in VTEC (meaning staying on top cam). Does the FIT's ratios do this from 1st to 2nd gear?
Old Mar 14, 2015 | 12:15 AM
oops fitmo answered my question. His answer says a lot. If the car stayed in VTEC it would do 0-60 in low 7's vs near 8 sec.
Old Mar 14, 2015 | 12:22 AM
Fitmo's Avatar
From what I've read the new DI engine VTEC isn't stepped--it's continuously variable.
khayward111
Feb 5, 2020 01:49 AM
Kluch
Dec 10, 2016 03:06 PM
Johnny150
Oct 2, 2015 07:30 PM
appleb
Dec 24, 2012 09:22 AM
CTStalker
Oct 7, 2008 07:27 AM
