Dipstick Question
Old May 28, 2017 | 08:19 AM
Carbuff2's Avatar
Just be thankful that we are not BMW owners. They have no dipstick AT ALL.
You need to drain and measure the amount of oil to get an indication of the amount. Yeah, they have a level; sensor, but they have been known to fail (one of Car & Driver's long-term test cars had the issue).
Old Jun 3, 2017 | 09:52 AM
max503's Avatar
Originally Posted by Sono
If you take a clean paper towel ( white or blue shop towel ) and lay the dip stick on it and roll it a bit you can see where the level ends fairly easy ( Had a jeep liberty with a dipper like these )
G
Going to try this.
I wonder if you could remove that plastic tip? Just wondering. Not going to try it on mine.
Old Jun 4, 2017 | 01:18 AM
Sono's Avatar
Originally Posted by max503
G
Going to try this.
for my 08 sport it is just the flat metal dip rod from hanle all the way down, just 2 holes at the end ( I checked it yesterday ) so I don't know if its aftermarket or original as I just got it used a few weeks ago.
Now my jeep liberty renegade had the cable type dip stick with the round plastic end which was a pita to read so I know what you are talking about but unsure if these on the fit were flat with the plastic ends or not and I don't know if mine was removed or replaced? Anyone have pictures? I can take a pic of mine tomorrow.
Old Jun 4, 2017 | 08:43 AM
max503's Avatar
Lets draw straws and the loser has to take the plastic off their dipstick so we can see if it works.
Old Jun 5, 2017 | 01:55 AM
dwtaylorpdx's Avatar
My 07 has an all metal dipstick, maybe compare the old to the
new and just get one used ??
Old Jun 5, 2017 | 03:30 PM
fitchet's Avatar
Just for the record, I had a 2010 Honda Fit Sport and I think it had a "regular" all metal dipstick. I don't remember having the same problem.
The plastic tipped dip stick is on my new 2016 Gen 3.
So at some point I think Honda cursed/blessed us with this change.
If you could prove and convince me switching dipsticks would give me accurate readings and no problem? I'd be willing to seek out a used one.
Old Jun 1, 2021 | 09:52 AM
Mr.G's Avatar
Sorry to extend this old thread, but I just purchased a used Honda Fit and everything is fine, except for how much I can't stand the plastic tip of the dipstick. It is so difficult to read! I read through the replies and tried the 'rolling on a paper towel' method, but honestly, I'm still frustrated. I'm a bit hopeful to hear that earlier versions may have used a metal dipstick, but does anyone know if it is interchangeable, or possibly found a suitable replacement?
Old Jun 1, 2021 | 10:26 AM
max503's Avatar
If you remove the dipstick from the tube for several minutes so that the tube has time to clear, then wipe off the dipstick before you insert, remove, and then read it - you won't have any problems.
Old Jun 3, 2021 | 07:40 AM
bill bosco's Avatar
i use a paper towel to make sure the plastic tip is oil free before i put the dipstick in , if you notice , one side usually has a lower reading , i go by that one . worse design i've
ever seen , and since the car is being discontinued , will probably never be fixed
Old Jun 3, 2021 | 11:48 AM
Fuelish's Avatar
Have the same type dipstick in my lawn tractor....and it's equally as frustrating!!!
Old Jun 7, 2021 | 07:14 PM
nmfit2008's Avatar
Dipstick
I have had two Fits, since 2008. With my 2019 Fit EX, I insist that the guy who is looking after me lets the car sit for 10 minutes, and then we both check the dipstick together (after the oil change). I also insist that
we check the oil % indicator, because sometimes they forget to reset that as well. My regular guy has a good attitude, and he knows I want this....so he does it with a smile. Not all of them would do that.
Old Nov 3, 2022 | 11:57 AM
  #32
Conniecapone@gmail.com's Avatar
Dipstick frustration continued
Here i am a year later than the last post complaining about it some more. I thought it was because I'm a dumb woman🤣 glad to know its not just me. I ended up here because I was wondering if there was an aftermarket replacement that was metal like every other car I've ever had. It is useless for me to even try to read the stupid dipstick. I get so frustrated. I thought of painting it white (sorry, I'm an artist) so I could see it better but pretty sure thats not a good idea🤣🤣🤣
Old Nov 3, 2022 | 12:43 PM
  #33
Odie's Avatar
SHARPIE Permanent Marker ( Extreme Fade Resistant ) black magic marker ? Yes , it can be bit difficult to read , especially after oil change . Make sure the car is on level ground .
Old Nov 3, 2022 | 05:40 PM
  #34
Brain Champagne's Avatar
Put the dipstick on a paper towel (horizontally) and you'll easily see where the oil is.
Old Nov 3, 2022 | 06:10 PM
  #35
Thanks, I will try that!
Old Nov 4, 2022 | 09:03 PM
  #36
BMWguy22's Avatar
Yes, please don't paint it.
Old Nov 4, 2022 | 10:40 PM
  #37
🤣🤣🤣 I won't. I was pretty sure that was a bad idea
Mister Coffee
24
Mar 17, 2024 12:54 PM
Ogrelode
Feb 24, 2019 09:14 PM
richsfit
Nov 7, 2012 06:10 PM
mozarwasagenius
Mar 31, 2009 12:54 PM
tk_jazz
Jul 18, 2008 04:49 PM
