Where to place blindspot mirrors?
I am thinking of getting some of those round blindspot mirrors for the drivers side rear view mirror. On the 2015 Fit, where is the best place to place it on the mirror? I have seen some on the top right, some on the top left...I guess it depends on the car. What do you guys recommend?
I recommend that you learn how to adjust your driver's side mirror so you don't NEED a "blind spot" mirror.
The trick is to set your driver's side mirror "out" far enough that you can't see the side of the car in the mirror until your head is almost resting on the window glass. If you do this, by the time an overtaking car "disappears" from your center rear view mirror, it will show up in the side mirror. No blind spot mirror needed.
I just recently drove a Ford Fusion on a road trip (yes I know much bigger car) but it has those blind spot mirrors built into the side view mirrors. I personally found it much easier to see cars on the drivers side of the car when changing lanes and such.
There are techniques on Youtube to get an idea on how to adjust the side view mirrors.
The technique I use is to adjust your rear view mirror so it frames your rear window. Notice the objects on both right and left edge of rear window. Now adjust each side view mirror so that each object slightly overlaps in each side view mirror.
I've put blind spot mirrors on several of my vehicles over the years, I find the most optimum location is the lower outside corner. They are also helpful when parallel parking or reverse parking (allows you to see the parking space lines, curb, etc).
Thanks for the advice. I know I got a lot of hate here for wanting one. However I like them in the past even on smaller cars for all the reasons you mentioned.
Yeah, you will always get a lot of varied advice and opinions, bottom line is if you like them and they help you drive more safely, put 'em on.
I've tried all those suggested adjustments for the driver's side mirror and how you have to have your head positioned and such, and I don't want to be turning my head if I don't have to. I got the round 360 degree adjustable mirrors and put them at the bottom left side of the driver's mirror and the passenger's. I only really use the passenger's for seeing a parking line or curb because while driving I use the camera for right lane looks, but for the driver's side, that curved big round mirror makes it so EASY to see several lanes and quickly lets me know where the traffic is to my left. They are great tools and your eyes will quickly learn to go to that spot where the blind spot mirrors are at.
Truth be told, I can't take credit for this. I learned it from "Click and Clack" on "Car Talk" on NPR many years ago. My Dad and I were habitual listeners.
I just can't get used to that built in "expanded view driver's mirror" (to me, it distorts the image and makes things worse), so I installed a couple of dedicated tiny blind spot mirrors, and now .... much better.
. Here's the famous advice with explanation + graphic: How To: Adjust Your Mirrors to Avoid Blind Spots - Feature - Car and Driver
Learned this one from my Dad + Car Talk as well
Either way, I got the information from you, so thank you.
NewFitGuy09
18
Oct 1, 2012 08:01 PM
