Homemade CDs ok or not ok to play?
Old Jul 27, 2015 | 10:29 AM
Mshellt's Avatar
My dealership warned me only to play CDs that were factory printed. They said that if I burned my own and the CD got stuck in the player, it would not be covered under warantee. ...That just doesn't sound right to me. Anyway, is it true? I would like very much to put together some mp3 CD's for the road. ( 2015 fit)
Old Jul 27, 2015 | 11:37 AM
Uncle Gary's Avatar
As the owner's manual points out, just don't use stick-on labels, and you should be fine. I burn my own CDs and use "printable" CDs, that I label using my inkjet printer.
Truth to tell, I carry my music library of MP3 files on a couple of thumb drives in the car these days.
More info as to what works and won't is on page 224 of your owner's manual.
Old Jul 28, 2015 | 02:27 AM
Mshellt's Avatar
Oh! Thank you--The dealership told me they did not cover privately made discs because the files could cause problems with the computer. It really bothered me to think the CD player might jam so easily, but if it's just labels then that's more understandable and easily avoidable.
Old Jul 29, 2015 | 02:27 AM
GeorgeL's Avatar
Originally Posted by Mshellt
...The dealership told me they did not cover privately made discs because the files could cause problems with the computer....
Honda says that CD-Rs will work in the CD player. There is an easy way to tell if the dealer is feeding you BS. Their lips move.
Old Jul 29, 2015 | 02:52 PM
Uncle Gary's Avatar
The only issues I've had with files causing problems with the computer is that the head unit is limited on the length of the file name it can read. I had to rename a few songs on my thumb drive so the unit could "see" them. Otherwise, it would just skip over them.
Old Jul 30, 2015 | 10:42 AM
FitFolksinger's Avatar
The player will try to read the meta data and perhaps ISRC codes but it won't effect the playing of a CD or not.
What you don't want to put in are CD's with stick on labels for heat can loosen them and the CD will jam. So be careful with the CD's you buy from local entertainment.
Silver Surfer
Apr 9, 2015 05:39 PM
gladel
Jul 5, 2014 05:49 PM
tonyg2k
Aug 23, 2011 12:42 PM
Scot
Dec 10, 2007 01:05 AM
andy23666
Oct 29, 2006 01:57 AM
