Unlock Lighting Mod?
Old Oct 4, 2015 | 12:19 PM
esnave09's Avatar
I don't know how many of you guys notice this kind of stuff, but I like that when GM cars are unlocked, their backup lights and their high beams come on for a brief time. I was wanting to see if anyone would know how to wire the backup lights to come on when the car gets unlocked. I just upgraded to LED backup lights, and figured that this would be a cool idea.
My original plan was to wire in a signal or power wire from the dome light's switch so that it would be controlled by the door setting. That's the simplest option in my mind, but are there any better suggestions? I figured that since the lights are linked to the ignition, I may need to run a power wire to the lights as well.
Old Oct 4, 2015 | 01:33 PM
Uncle Gary's Avatar
You DO realize that if your lights are set to "auto", the headlamps and tail lamps will come on when you open the door at night, right?
Actually, I'd like to disable this silly and useless feature. Starting the car with the lights on just puts an unnecessary strain on the Fit's already undersized battery.
Old Oct 4, 2015 | 01:38 PM
esnave09's Avatar
I know that the headlights come on with that setting, I use it all the time. I want the reverse lights to come in then too.
Old Oct 4, 2015 | 02:05 PM
TorontoBoy's Avatar
Use a relay. The trigger would be the dome light. Wire power directly from the battery to the relay, and the backup lights to the relay, triggered only when the dome light turns on.
Dome light turns on, allows power from the battery to go through to the backup lights. Dome light turns off, power from the battery is cut to the backup lights. Otherwise the backup lights work as usual.
Old Oct 4, 2015 | 06:20 PM
LLLC1393's Avatar
This is why I turn the auto headlamp off before turning off the engine at night, and only turn on the auto function after starting the engine. I do like the headlamps coming on with the wipers, and have no issue with starting the car with headlamps on. My problem is them staying on after I turn off the ignition, or when opening the door. That makes me nervous about battery drain. It would be nice to be able to customize the delay here. Many cars allow you to do so.
Old Oct 5, 2015 | 04:05 AM
GolNat's Avatar
I find it annoying, especially when I am in a parking lot waiting for a vehicle to back out that isn't actually backing out.
Old Oct 5, 2015 | 04:19 AM
DWils's Avatar
Same. It sends the wrong message.
Old Oct 5, 2015 | 07:49 AM
Uncle Gary's Avatar
I understand the lights staying "on" after you shut the car off, so you can find the house door, or what ever. But having them turn "on" when you open the car door is just silly. I'd use the auto setting more, but having the lights come on every time I open the car door in the garage is silly IMO.
Old Oct 5, 2015 | 10:56 AM
Howie_Feltersnatch's Avatar
This would be great... Someone is tailing-gating, flip on the dome light and the reverse lights come on. panic sets in.
Old Oct 5, 2015 | 10:17 PM
esnave09's Avatar
That would be really nice in my opinion too! I have to load and unload a full load of sound equipment (full trunk and seats folded), and the second load of the night is always in the dark. I'd like to be able to use the backup lights as illumination since there is zero outside light there. I've been leaving the ignition on with the shifter in reverse, but pretty soon it'll be cold enough to want to leave the car running and this is not an option.
I know, it's a big old load of first world problems, but if there's something I can do and it's relatively easy, then I'm gonna do it! Although I would imagine that it involves removing the headliner and trunk lining, so this could be more of a task than I am up for. We'll see.
Old Oct 6, 2015 | 11:40 AM
2Rismo2's Avatar
Reminds me of this...
Old Oct 6, 2015 | 03:46 PM
TorontoBoy's Avatar
This would be a problem, and would be illegal in a moving vehicle.
In your case it would be easier to wire a switch from the rear lights to the backup lights. When the rear lights are on, the switch is active and could turn on the backup lights. A little unconventional, and if you leave it on by accident and drive, illegal. You could also add an extra rear compartment light, with a switch, which would be easier, not illegal but provide less light. Or add an extra LED flood light pointing to the rear. Either solution only requires moving panels at the back, and not touching the head liner, and very little of the trunk liner.
Old Oct 6, 2015 | 03:59 PM
Black3sr's Avatar
I replaced the trunk light with a couple of 9 panel LEDS. Solution to problem is to add a couple of these to the hatch door itself connected to the hatch light. These would light up the ground behind car.
Old Oct 6, 2015 | 04:16 PM
TorontoBoy's Avatar
Good idea. That would certainly solve the...problem. I'm not sure what the problem is, as the OP has changed requirements and went slightly off-topic, on his own post...
randyapigo
May 15, 2012 06:43 PM
cndfit
Jan 24, 2011 10:24 PM
AnlDyxp_GD3
Jun 4, 2010 02:01 AM
SCBarren
Nov 30, 2009 10:21 PM
Tomsfit
Nov 3, 2007 08:44 PM
