Front Passenger Door Leak - Fixed
Old Feb 12, 2016 | 11:35 AM
Octopy's Avatar
I saw there were a few people here with the problem of leaking doors and to my horror I found I have the same problem. Leaking doors is a seriously big problem if you live up here in the Pacific Northwest :P
Honda referred me to a local body shop because they cannot fix or diagnose water leaks. It took 20 minutes but they found the problem and fixed it on the spot. Guy there said my car was the 3rd fit they have seen with the problem. The rubber seal around the door frame was a tiny bit too small for the door so they had to replace it with one the proper size. Basically the seal start to pull away and allows water to leak down and soak into the floor. They ran the water test and I came back today to find out that fixed the problem.
Vin: late 2014 Mexico. 2015 EX-L.
Anyway, hope this helps someone else. It almost caused me to have a heart attack.
Old Feb 15, 2016 | 07:14 AM
rodney's Avatar
i am not sure which seal you are talking about. do you have pics of the repair?
Old Feb 16, 2016 | 01:36 AM
nullxposur's Avatar
I had the same issue on my rear driver's side door. I think my Honda Care covered it though because I didn't pay anything. My carpet would basically always be wet after driving through the rain or even a drive-thru car wash.
Old Feb 16, 2016 | 01:41 AM
KikeDiaz's Avatar
So which doors all the doors? Mine is always garage so I can not know if I have the problem. Where should I look or what to know if I will have the same problem in the future. Pics will work wonders
Old Jan 24, 2017 | 07:13 PM
Mbalcorta's Avatar
similar issue
I live in the bay area and this is the second year in a row that my honda fit 2015 has a wet driver side passenger carpet The first year they fixed everything and replaced the carpet this year they refuse and blame it on something else. Is your car no longer leaking/have you check this season? Thanks for any info.
Superscottia
Aug 26, 2016 03:41 PM
Edub
Ohio Community
Apr 15, 2015 08:26 AM
geepondy
Mar 30, 2014 07:53 PM
p1driftfiend
Sep 20, 2011 12:01 AM
jazz_do_it
Jun 29, 2011 08:45 AM
