Both headlight bulbs burned out before 77,000 miles
Old Apr 27, 2016 | 05:00 AM
Namae Kana's Avatar
F.Y.I. I always turn the low beams on during the daytime. I have almost 79,000 miles on my 2015 Fit CVT LX. Both bulbs burned out, the 1st around 65,000 miles, and the 2nd around 76,000. Seems the bulbs have a short lifespan.
Old Apr 27, 2016 | 05:43 AM
MelR's Avatar
Hmmm...I just traded my 2007 Fit with 250000k, and its original headlight bulbs, in on a 2016. Maybe I should have kept the old bulbs?
Old Apr 27, 2016 | 05:51 AM
Namae Kana's Avatar
Maybe my driving all over the USA through the snow, sub-freezing weather, and desert conditions has worn out the bulbs earlier than expected. I also had to swap out the Mitsuba starter this week since it had been flaky.
Old Apr 27, 2016 | 07:26 AM
bladhmadh's Avatar
I had to change both front lights and the tail lights over the same mileage on my last vehicle.
Old Apr 27, 2016 | 07:32 AM
Uncle Gary's Avatar
Let's see here, 65,000 miles divided by, let's say optimistically 50 MPH average speed=1300 hours. This is WAY over the rated life of any H-4 bulb I know of. The "high output" bulbs I'm using (Sylvania XZE) have a rated life of 100 hours. If I get a year out of them I consider myself lucky. I'd say you did pretty well
As my ex wife used to say, some of you would gripe if they hanged you with a new rope.
Old Apr 27, 2016 | 09:21 AM
Fit_as_a_butchers_dog's Avatar
zOMG, Honda should be dragged through the streets, and pilloried for their bulbs.
Wait, does Honda even make bulbs?
Old Apr 27, 2016 | 03:35 PM
Uncle Gary's Avatar
The stock bulbs in mine were labeled "Phillips".
Old Apr 27, 2016 | 08:20 PM
DrewE's Avatar
High output bulbs have much shorter life than regular plain bulbs. Regular bulbs are typically rated to last around 1000 to 1200 hours.
70k miles or so doesn't seem at all out of line to me. I replaced both my headlight bulbs not long ago, at around 75k miles I think, when the high beam on one of them burnt out. They're a consumable item, just like tires and wiper blades and belts and brake shoes.
Old Apr 27, 2016 | 09:05 PM
James Butler's Avatar
My stock 9004 bulbs went for 16 years with no problem. I put in a set of cool blue 9004 bulbs for a brighter output and had one burn out in 6 months.
Sorry more output = less life
James
Old Apr 28, 2016 | 07:45 AM
Uncle Gary's Avatar
James
It's "hours" on the bulbs (mileage) not "years". Park the car and the bulbs will last forever.
Like I said, 60-70,000 miles is standard or better for OEM headlamp bulbs. I usually end up replacing my OEM bulbs somewhere around there, so I don't know what the OP is complaining about.
Old Apr 28, 2016 | 10:22 PM
raytseng's Avatar
your expectation is off. 1300-1500 is the right expectation, esp if you're leaving the lights on all the time. At this rate oh noes you'll need to replace the bulbs again at 150,000 miles and then 225,000 miles.
Only if you had HID bulbs though, then you should be expecting like 2000-2500hrs, but the bulb replacements are also much more expensive.
Morair
May 9, 2012 08:26 AM
sdiesel619
Oct 18, 2010 01:21 PM
Santiad
Jan 26, 2010 03:31 PM
Chazzlee
Dec 2, 2009 08:49 PM
pedaler
Nov 28, 2006 11:51 AM
