Changing Headlight Bulbs - Gen 3
Old May 26, 2016 | 10:45 AM
Bob Levine's Avatar
Was thinking of upgrading headlights to slightly brighter bulbs as I did in my Corolla.
Read the owner's manual and looked at online videos of older generations.
Is it possible to change the bulbs easily? Must the splash shields be removed?
Don't think the dealer would install other than standard bulbs.
Thanks.
Old May 26, 2016 | 12:38 PM
COBEs's Avatar
Changing the headlight bulbs is extremely easy, and only requires you to open the hood for access. There's a rubber boot on the rear of the headlight assembly covering the bulb, pull it off to get access.
Bassguitarist1985's Avatar
Headlights are easy to get to. And fogs you have to remove one screw on splash shield to open an access door to change them.
Old May 26, 2016 | 04:44 PM
Bob Levine's Avatar
Thanks, thought the metal holder unswe the boot was an issue.
Old May 27, 2016 | 12:27 AM
Nope, push in, move down, and it swings out of the way like a door to release the bulb.
sdiesel619
Oct 18, 2010 01:21 PM
Chazzlee
Dec 2, 2009 08:49 PM
JDMGD3
125
Nov 21, 2008 10:30 PM
crushbent
Apr 20, 2008 06:08 PM
Chikubi
Jun 2, 2006 03:19 PM
