LED lamps: CAN Bus vs Regular?
Old Sep 18, 2016 | 11:43 PM
doop's Avatar
I'm about to replace all the interior lamps in my Fit. My LED vendor has "CAN Bus" lamps and the same thing but without the CAN Bus. But they don't recommend one over the other for the 2016 Fit.
Which do I need?
(I realize this is a pretty dumb question...)
Old Sep 19, 2016 | 07:01 AM
Carbuff2's Avatar
It's NOT a dumb question.
Some vehicle's CAN BUS systems rely on specific resistances to work as designed, so changing to the lower resistance LEDs will cause erratic operation.
If the answer isn't forthcoming (have you asked more than vendor, specifically?), I'd order the CAN BUS lamps to be safe.
I don't know the answer, myself.
Old Sep 19, 2016 | 09:26 AM
Uncle Gary's Avatar
I used "regular" (non CAN bus) LED interior lamps in my '15 Fit for dome, map, license plate and trunk lights. They worked just fine.
Old Sep 24, 2016 | 01:50 AM
Gorilla's Avatar
We put in regular generic ones for the all the interior fixtures without any issues. Hint: Make sure there's no power going through the circuitry when installing or you could definitely blow a fuse.
Old Sep 24, 2016 | 09:45 AM
James Butler's Avatar
The LED replacements only work one way. If it does not light just reverse it in the fixture.
James
Old Sep 24, 2016 | 03:40 PM
Bassguitarist1985's Avatar
GK5 lamps are not CANBUS type. And LEDs are high resistance and they draw little current. If it were a CANBUS light system thosr Lights have internal resistors to present a load to the socket so the idiot dash light saying the bulb is burnt out stay off.
jukeboxx13
Feb 17, 2018 11:27 PM
XenithXenons
Aug 27, 2010 01:51 AM
EUROz*JDMz
Apr 8, 2009 05:20 AM
umiekun
May 21, 2008 01:15 AM
Hyper Ledz Neon
May 4, 2005 11:16 AM
