REALLY conservative gas gauge?
Old Jan 27, 2017 | 11:21 AM
JonTu's Avatar
Originally Posted by GeorgeL
I've had the range indicator down into single digits and then put in a bit over 10 gallons. Considering that the tank is advertised at 10.6 gallons I am reasonably satisfied at the accuracy of the range meter. The fuel light seems to come on with about 30 miles of fuel remaining, again a reasonable amount.
I wonder if the people who are complaining are filling their tanks completely? The Fit tank will take nearly two gallons after the nozzle clicks off automatically. That long fill pipe makes it fill a lot slower than other cars for the last few gallons.
FWIW, I ran mine about 8 miles past the "Range: 0.0 miles" point on one occasion and there were still over a gallon of fuel in the tank (50+ miles of fuel range based on my average MPG) when I filled it. I'm sure the fuel pump pickup can't get every drop, but this reading 0 with over 10% of available fuel remaining does strike me as overly conservative.
Regarding topping off the tank, the Fit has an evaporative vapor recovery system, so filling up to max capacity can cause issues. If liquid fuel winds up way up in the filer neck, the EVAP can get tripped up, popping a check engine light. The advice I have gotten is fill until it clicks off, hit it once more until it click off a second time, and then stop.
Old Jan 27, 2017 | 03:20 PM
wasserball's Avatar
I use those post-it stickies to cover up the low fuel warning gas pump icon when it comes on. Black electrical tape leaves a residue.
And, if you are filling your tank less than 11.165 gallons, you still had miles to go.
Brain Champagne
Sep 16, 2018 01:55 AM
Fox944
Oct 6, 2014 02:44 PM
DeltaBond
Jul 23, 2013 12:20 PM
yeeman
Nov 9, 2007 04:58 PM
Sera
Apr 14, 2007 01:43 AM
