Radio and back up camera shut off then came right back on?
Old Nov 7, 2016 | 10:20 AM
ncoflin's Avatar
Hello all
I have a 2015 Honda Fit LX with approximately 50k miles on it. Today when I was leaving from a parking garage backing up my radio turned off and back up camera went black, I believe I heard a little click. I immediately stopped and pulled back into my space where it all came back on. The radios presets were all gone and clock completely reset. As I continued to drive turning the car on and off several times it appears to be fine. What do you think would cause this? Have any of you had a similar problem?
Thanks
Old Nov 8, 2016 | 08:13 AM
ive not had this problem but make sure that ur battery connection is sound under the hood. if it was loose the car would show more problems, but its easy to check so start there.
also just check the fuse box to see you dont have any loose fuse.
if it keeps happening i would unplug the HU from the car check the contacts in the harness. if u see corrosion wipe it down with WD40 using a Qtip until u see the metal, then plug it all back.
SilverEX15
Dec 2, 2018 02:53 PM
Hector Uriel Burela
Jan 5, 2018 07:06 AM
dickiez
Apr 4, 2010 12:09 AM
Fit of RAGE
Sep 24, 2009 10:32 PM
paulf5164
Sep 9, 2007 10:44 AM
