GK5 Fog Lamps/DRL Installation Problem
Old Nov 24, 2016 | 01:49 AM
bim27142's Avatar
Hi Guys, newbie here and desperately needing some advice.
I just recently got my Jazz (from Philippines) installed with a Fog Lamps and DRL (both Honda Access kits). I have it installed from the dealer, hoping installation would be seamless... apparently that was not the case.
I immediately saw the following issues:
1.) Harness seem misrouted as I can see it floating just in front of the radiator running across to the other side just passing the horn.
2.) The orientation of the DRL's seem incorrect as both seem to be facing one side (sorry don't know how to describe it but basically - facing the car, LED's on the left are outwards while LED's on the right are inwards).
3.) Last and certainly not the least and probably the biggest issue of them all, if I am stepping on the break and I place it to "Park", the DRL's turn off... It turns back on when I either release the break or disengage from "P".
Thank you for any help/advice you could give to me.
Bim
NRG
Sep 27, 2016 09:44 PM
NotBlake
Oct 18, 2014 04:47 PM
FITMugen
Mar 1, 2014 10:29 PM
bobos105
Apr 30, 2010 04:24 AM
FELIXY69
Jul 27, 2007 12:30 PM
