backup camera
Old Dec 9, 2016 | 05:31 PM
fred9000's Avatar
backup camera
hello everyone !
is anybody find a way to use an aftermarket screen headunit with the oem backup camera
is there some kind of adapter to use the existing camera , all aftermarket radio use rca input
Old Dec 11, 2016 | 12:28 AM
fred9000's Avatar
more than 110 view an nobody answer ? i suppose i am stock with this crapy thing ....
Old Dec 11, 2016 | 08:58 AM
James Butler's Avatar
fred9000 :
The head unit of the Fit uses a special format for camera inputs. There may be other units made for Honda that would work. Using a Kenwood or Alpine double din unit in the dash is possible and has been done but you loose the camera function. Since aftermarket units have standard composite video input you can buy your own composite camera and mount it in the back to get that function back.
Sorry
James
Old Dec 11, 2016 | 12:35 PM
ezone's Avatar
When I was adding a backup cam to my 12 Civic about 4 years ago........ I remember reading something about the OE cameras using some non-standard voltage to operate, like 8v instead of 12v, which is why aftermarket backup cameras usually take power from the reverse lights while the original camera received its (8v?) power through the stock head unit (or IMID in my car).
The video signal should be standard, but it looks like your OE camera has 8 wires (7 plus a shield), the extra wires are probably to accommodate the available multiple views.
If you could figure out how to supply the camera with the correct voltage to operate, it may still work with your AM head unit but unless that unit will accommodate multiple signals you'd probably have to pick one 'view' and live with it (or use a separate switcher?).
Otherwise, I think I gave under $15 for my backup camera assembly (came with license lights for my Civic application) from Alibaba, and its cameras dimensions were pretty similar to the stock cameras I have seen.
My only gripe is my aftermarket cam has its own 'guidelines' built in to the signal and I can't change that.
HTH
Old Dec 11, 2016 | 03:34 PM
fred9000's Avatar
thanks , thats i figure already , that i need some kind of adapter because of the honda camera plug
i dont know if the signal on wifi camera is good , i could install that , it would be simpler to install and they have standard rca signal
Old Jan 17, 2017 | 06:20 PM
fred9000's Avatar
i finally will mount a alpine ics x7hd
with an after mariket rear camera , are somebody have a suggestion to make for an after maket rear view camera that i can mount on back in place of the oem ?
i have already test the rear camera setting in the head unit , to bad i can't use the oem camera , or maybe somebody have a suggestion also
Old Jan 17, 2017 | 06:38 PM
ezone's Avatar
build a voltage regulator circuit to run the stock camera at 8v? (need to verify that's the actual operating voltage by testing using the stock head unit first)
Old Jan 17, 2017 | 11:46 PM
KikeDiaz's Avatar
That's cool that USA version can only buy a aftermarket stern and mounted. Mex fit doesn't have it so you need to buy the hole unit.
https://www.autologia.com.mx/wp-cont...ool-201505.jpg
So I bought an cd mount and I mount my phone and It is like having a display with all the features(android auto, internet, ware, music, video). Pretty cool setup buy I want a backup Camara for convince even though my fit has backup sensors.
I am looking forward to a rear view mirror with auto dim and backup camara. That will be a nice upgrade.
Old Jan 18, 2017 | 05:00 PM
TorontoBoy's Avatar
I know you've been looking for a head unit for your Fit. No integration with the backup camera is unfortunate. Head Unit manufacturers are just not fast enough to keep up with all the new cars.
Is the Fit's 5.5" non-touch screen so bad? I really like mine, but I'm not too picky.
Old Apr 22, 2017 | 05:56 PM
fred9000's Avatar
the oem head unit is fine but i am very picky for audio quality
tocirahl
Apr 24, 2019 11:14 PM
SilverEX15
Dec 16, 2017 05:46 PM
Press Fit
Sep 17, 2016 07:26 PM
c3kay
Mar 12, 2015 05:53 PM
ADVphotography
Oct 27, 2014 11:25 AM
