Air/Fuel Gage GK
Old Dec 30, 2016 | 01:01 PM
Exgk5's Avatar
Smile Air/Fuel Gage GK
Hi Guys,
I have an Air/Fuel Gage and I want to install it to the GK. Now, I know that it doesn't really pull correct numbers and is just a light show, but I still want to have it on my dash.
My problem is, I have 3 wires and I'm bad at electrical lol.
black of course is ground
white they said is O2 sensor
and Purple for ignition switch
Before I had it on my EK, so there, it's pretty spot on.
On the GK I have push button, I need help on where is the easiest wiring diagram I can get to get this project of mine done?
all the help is much appreciated.
Thank you
Old Dec 30, 2016 | 07:37 PM
wasserball's Avatar
before you tackle the wring colors, I suggest using a volt meter to assure yourself the color of the power wire so you don't fry some wires or blow a fuse. The convention for house wiring is black is HOT, green GROUND, and white RETURN.
Old Dec 30, 2016 | 09:08 PM
BMW ALPINA's Avatar
Originally Posted by Exgk5
Hi Guys,
Thank you
Hello,
The easiest way if you can't find the wiring diagram is to buy this:
https://www.amazon.com/dp/B00C9QT8E2...I2E0DSBQAY6493
Then plug in the fuses (2 fuses, one for current line that you tap and one is for the supply line that goes to your A/F ratio gauge).
and then test it on any of the empty slot or any slot on the fuse box that turn on whenever you turn on the ignition/engine
by the way,
I am currently using the AEM UEGO A/F ratio gauge and the number it show is VERY Accurate and if you tune your car, it is not just a light show but a really vital indicator.
Old Jan 2, 2017 | 10:24 AM
is ur car running forced induction? not sure da reason for a/f gauge on a NA stock or fairly stock car.... in fact I own two turbo charged cars and even on those cars i don't run a/f gauges. I have da capability to log a/f ratios though...
LLLC1393
Sep 21, 2015 11:44 AM
nicco
Mar 25, 2015 06:57 AM
xxryu139xx
Mar 13, 2015 07:35 PM
xxryu139xx
Jun 21, 2014 07:35 AM
tmfit
Jun 12, 2014 08:53 PM
