Window sound
Old Apr 21, 2017 | 02:26 AM
puffysweater's Avatar
Window sound
Sometimes, when I roll down either of my two front windows, they make a sound similar to windshield wipers dragging on glass. It's obviously not as loud, however it is still noticeable. Does anyone else experience this?
It happens maybe 50% of the time I open one of the front windows. Haven't tried the rear, since I don't usually have rear passengers.
Old Apr 21, 2017 | 07:43 AM
if its humid it might do that.
Old Apr 21, 2017 | 10:34 PM
Jack Hammer's Avatar
Most people are unaware that they should periodically lube the rubber part the glass slides in with some silicone spray. The windows will drag a little and can stick or make noise if left unlubed. Just get some and spray those areas then roll the window up down a few times as it dries to get it on the lower portion.
Old Apr 24, 2017 | 08:14 AM
wasserball's Avatar
You have my permission to try the rear windows operation.
Old Apr 28, 2017 | 09:51 PM
Gregg's Avatar
My 15 LX front Driver's side window makes a very labored motor sound going down when the inside of the car is hot from sitting out in the sun. I've been reporting it to my dealership every oil change for the past two years. They always claim they can not get it to repeat.
I think mine is caused by improper clearance between the glass and the seals on the door.
When the door gets hot, things expand some, and the window drags going down.
The other three windows work smoothly with out any funny noise.
Piyo2005
May 13, 2013 03:47 PM
captainhowdy
Feb 14, 2013 12:53 AM
BlueBoogers
Oct 17, 2011 08:52 PM
jjanaya21
May 27, 2009 10:50 PM
garett
Aug 2, 2006 12:35 AM
