Plastic screws stuck
Old May 11, 2017 | 11:52 AM
puffysweater's Avatar
These two plastic screws for the under cover are stuck and ive pretty much destroyed the philips head by constantly trying to unscrew them.
Is there a specific technique to take these off??
Old May 11, 2017 | 12:04 PM
2Rismo2's Avatar
Use a flathead screwdriver and just pry it off. Have replacements on hand
Old May 11, 2017 | 04:38 PM
TorontoBoy's Avatar
Buy a couple of replacement expansion plugs, before you destroy the existing ones.
Use a flat head screwdriver, wedge it under the head of the plastic screw and force the head up. Otherwise just use force and destroy the screw.
Old May 11, 2017 | 06:47 PM
Fuelish's Avatar
Our CPO LX came with th4e undercover gone daddy gone.....and I so no need other than for a maybe slight increase in mpg.....and I' overjoyed with what I'm getting - don't do a lot of hwy driving other than vacations, so ...I don't miss what I never had
Old May 11, 2017 | 07:05 PM
u have to go REAL easy on those tabs.
at this point you'll have to break them off I suppose. hold the screw head with a straight pick tool to prevent it from spinning and drill a small hole next to it. just drill through and pull out the screw portion.
Old May 11, 2017 | 09:35 PM
robs's Avatar
Just take something sharp. I use a raiser blade.. Use Phillips to turn screw.. turn with Phillips then pry open with raiser blade.. I've done 11 oil changes.. still factory fasteners...
Old May 13, 2017 | 01:38 PM
Uncle Gary's Avatar
Problem is the screws are easily damaged during removal if the tech isn't careful, and even my local dealer doesn't stock them, let's alone Wally World. If one of them is damaged, and no replacements are available, what do you suppose they do? Right, they shove it back in and hope for the best.
Old May 13, 2017 | 10:44 PM
ddfit151's Avatar
I picked up a few at the dealer. They had to order them, they don't stock them. Now that seems strange and confirms why some people having their oil changed at the dealer end up with the shield coming off.
Part Number 91514-TG1 T01 .75 cents each
Old May 14, 2017 | 11:37 AM
wasserball's Avatar
I've heard so many horror stories about the under pan that I will ask the service dept to leave it OFF when I get my first oil change. Stories like the pan comes loose, rattles, and the worst can happen; dragging on the road. How embarrassing.
Old May 14, 2017 | 11:49 AM
it's really not THAT bad... its the dealers and their express oil change folks screwing it up.
ive removed the GK's lower shroud 3x now for oil changes and washing the under carriage. no issue.
Old May 14, 2017 | 03:18 PM
Uncle Gary's Avatar
This is why I prefer to do my own oil changes instead of trusting the job to some ham-fisted hammer jockey (my Father's term).
Old May 14, 2017 | 04:34 PM
wasserball's Avatar
Out of curiosity. Do you elevate the Fit with ramps or jack stands?
Old May 14, 2017 | 05:09 PM
2Rismo2's Avatar
I use ramps and it's a piece of cake.
As others said, it's easy to remove and I've done it a few times for oil changes. Funny the only time a screw was left off was when the dealership did it because the first oil change was free. Of course I knew to double check after the work was done but only when I got home.
Old May 14, 2017 | 07:06 PM
wasserball's Avatar
My intention is to get my first oil change for free, ask them to leave the under cover OFF. Return all bolts and clips to me. Thereafter, I will put the front end on a Rhino ramp and change my own oil/filter. Shouldn't take longer than 10-15 minutes. BTW, I never warm up the oil when I change out the oil in my other cars. I never found that to be necessary.
Old May 14, 2017 | 08:20 PM
2Rismo2's Avatar
Yes I don't warm up the fit to change the oil, other than driving up the ramps. 0w-20 is pretty thin and flows easy.
Old May 15, 2017 | 09:14 PM
ddfit151's Avatar
I'm using "Race Ramps" which are made out of some sort of high tech foam. Works very well and good for 1500# each. I still have a concern about this material and always place the jack stands with just a little clearance as a back up.
Old May 16, 2017 | 12:31 AM
dwtaylorpdx's Avatar
Lots of folks have had issues with higher mile fits AC clutches, without the under-tray the pump hangs at bumper level on my GD, ran mine for a while without the tray (It was trashed from PO.. and as soon as it rained the clutch would slip and squeal until it warmed up (Each time the defroster cycled and no it was not the belt... ). With the under tray it stays dry.. I bought a tray off amazon and it has a cut-out for filter access and the drain.
YMMV..
Old May 16, 2017 | 07:36 AM
in salt belt states, that shroud prevents undercarriage wash water to get to the components below that need to be rinsed of salt. you have to remove it to wash ur undercarriage properly.
Old May 16, 2017 | 11:14 AM
Uncle Gary's Avatar
Homemade ramps made from three overlapping layers of 2X10" boards.
Old May 16, 2017 | 11:24 AM
Fuelish's Avatar
Should not the thread title be 'Plastic Screws Suck" ?
