Tailgate won’t open
Old Dec 25, 2017 | 07:16 PM
FitRaptor's Avatar
Tailgate won’t open
2016 Fit, rear tailgate won’t open/operate even if I press the unlock button on the fog. I hear no mechanism when I press the button. I’m thinking is a fuse? But I would like to know if anyone else has dealt with this before. Thank you
-Herman
Old Dec 25, 2017 | 08:17 PM
wasserball's Avatar
I tried locating the fuse for the tailgate but unable to find it, or understand the abbreviations. The fuse box information is on pg. 425, and emergency on how to open the tailgate from the inside is on page 429 of the owner's manual. good luck.
Old Dec 25, 2017 | 10:20 PM
FitRaptor's Avatar
Thank you sir I’ll tackle this issue 1st thing in the morning. I’ll report back.
Old Dec 26, 2017 | 03:16 PM
FitRaptor's Avatar
Opening it manual did the trick. After releasing the mechanism everything went back to normal. Thank you 🙏🏽
Old Dec 27, 2017 | 12:45 AM
woof's Avatar
Maybe a lack of lubrication issue - something just sticking.
Old Dec 27, 2017 | 10:14 AM
FitRaptor's Avatar
Yea I thought the same thing but when I opened the tailgate manually I saw that it had lub already and plenty of it. I’m begining to think that my wife probably closed it but didn’t put enough force to lock it. Maybe got stuck in between. As soon as I opened it and closed it everything else went back to normal.
Old Dec 27, 2017 | 10:31 AM
yah, that's possible. as long as it doesnt occur on a regular basis, im sure it's fine.
Old Dec 27, 2017 | 02:17 PM
FitRaptor's Avatar
Thank you gentlemen and or ladies.
Old Dec 28, 2017 | 04:36 AM
n9cv's Avatar
Was it frozen? Did you wash the car and get water in it?
Old May 10, 2018 | 06:37 PM
FitRaptor's Avatar
After 5 months the problem came back! 😫 this time for good I think. I opened it manually and failed to reset. Nothing works. I will try and find the fuse and go from there.
magellows
Sep 24, 2018 03:56 AM
LarryS
Jun 24, 2016 03:29 PM
Gabybeba
Jun 11, 2013 05:07 AM
hondafitblue
Mar 22, 2010 10:06 PM
trancedsailor
Dec 31, 2008 07:40 PM
