Will it "Fit" - Koni 1125-1029
Old Feb 28, 2018 | 02:50 PM
Z062FIT's Avatar
LM Performance has this kit (currently out of stock). Does it fit the GK5? Thanks in advance.
Koni 1125-1029 - Koni Honda Fit STR.T Kit; 2009-2013. Koni 1125-1029 Model Fitment Application: Honda Fit; Kit (New Kit will be available February 2016)
-d
Old Mar 8, 2018 | 03:03 PM
CommanderSlug's Avatar
After I exhausted the internet, turns out the OE struts on the 9-13 are 2 inches shorter than the GK's. I checked out the newly released KYB and Gabriel parts and although the mounting brackets are the same, the length is different compared with the GE struts; but GE struts will work on GK fits:
Others have installed the Koni 8750 1102L/R & 8050 1131 on the GK and report good improvements over OE.
KONI 8750 1102L - KONI STR.T Orange Shocks & Struts - FREE SHIPPING!
I just did some emailing with Koni and they say if a strut kit is installed on a model year not listed in the koni catalog, then there's no warranty coverage. Of course, if you get a defective unit out of the box, that's a different story [imo] but at the end of the day ... the choice is yours.
Old Mar 21, 2018 | 05:32 PM
PolymathPaul's Avatar
CommanderSlug,
Is this to me that if those of us with a GE8 installed the GK struts on our GE8, we'd get slightly more travel if used with a taller spring?
Old Mar 22, 2018 | 12:34 AM
I am guessing that should be the case if GK struts mounted on GE. Notice the 2 inch difference in extended/compressed lenghts. Travel stroke difference is less than 1 inch.
I found some specs for the following:
KYB 338002 (09-13 fit)
Extended Length (in) 18.97
Compressed Length (in) 11.92
Stroke Length (in) 7.05
Dust Cover Included No
Rebound Stop Yes
Compressed Bump Stop No
Upper Mount Type 12x1.25
Gabriel G52152 Ultra Struts (GK fit)
Shock Extended Length: 21.77 in. 552.96 mm.
Shock Collapsed Length: 13.93 in. 353.82 mm.
Length of Stroke: 7.84 in 199.14 mm.
Accessory Kits: n/a
Upper Mount Code: n/a
Lower Mount Code: n/a
Weight 8.16 lbs. 3.7 kg.
Old Mar 22, 2018 | 03:05 PM
I wonder why they did this?
Old Mar 22, 2018 | 05:39 PM
New chassis, new powertrain ... new everything.
Kyle05STi
May 20, 2019 11:21 AM
jrv784
15
Nov 4, 2018 11:53 AM
etasDustin
3rd Generation GK Specific Suspension & Brakes Sub-Forum
36
Sep 22, 2017 07:45 PM
jhn
Mar 30, 2015 09:42 PM
taFITta_sport
Apr 7, 2008 10:15 PM
