Best psi for MPG?
Old Apr 9, 2018 | 10:24 AM
Hawkeye's Avatar
Best psi for MPG?
I searched the forum and the mileage thread but "no results" came up even though I'm sure this has been discussed.
What is the best psi to use for MPG with the stock 16" wheels/tires on a 2018 EX-L CVT?
I currently have them set at 32 psi.
Thank you.
Old Apr 9, 2018 | 10:43 AM
Alco RS-1's Avatar
I'm no expert with this sort of thing, but I'd imagine that MPG would correlate with tire pressure, ie the higher the better. However, your economy gains will be lost in excessive tire wear as the center tread will wear more quickly than the shoulders.
I run about 32 PSI too, sometimes going to 35 when my kid takes the Fit off to college and I want to add a little insurance against leakdown.
Old Apr 9, 2018 | 11:16 AM
2Rismo2's Avatar
Agreed with PSI to Tire wear. Now I ran mine on 35 PSI and still managed 40k on the stock Firestones. Also driving style and road construction are variables to consider. I easily manage low 40's MPG and if I really pay attention I can get 44-45. Moon and stars aligned once and I got 47.
Old Apr 9, 2018 | 06:10 PM
bigdeezy's Avatar
I have a 13 and run them at 38 psi. I average 37.5 mpg highway and have nights where I get 40 mpg. Going from 34 psi to 38 psi got me from 35 mpg to 37.5 mpg.
Old Apr 9, 2018 | 06:37 PM
Hawkeye's Avatar
Thank you for the thoughtful responses. I think I will try a higher setting for a period of time. I used 40psi on our Volt, I might go that high just to see if the handling gets unbearable. I'll report back. Thanks.
Old Apr 9, 2018 | 07:24 PM
with everything in mind (in consideration) i run 36-38psi on the GK.
Old Apr 10, 2018 | 09:33 AM
drrusshorn's Avatar
2018 EX with OEM Firestone FR740s. I started out with 33/32 PSI per the specs on the door and averaged 32.5 MPG in mixed driving. I then increased the tires to 36 PSI (these Firestones say 40 PSI max on the sidewall) and am now getting 35.3 MPG with the same set of daily driving conditions.
Old Apr 10, 2018 | 12:18 PM
MelR's Avatar
I run mine at 34-36 PSI. Seems like a good compromise between efficiency and comfort. In my previous Fit I experimented with higher but the benefits seemed marginal at best.
Looking at Fuelly.com, I seem to have the highest average MPG for all the 2016 fits on there. 99 fillups and no bogus data. Two Canadian winters with snowtires included.
Old Apr 10, 2018 | 02:39 PM
ashchuckton's Avatar
Many years ago my wife & I took part in a fuel economy run. I pumped up the tires to 75 PSI. I was hypermiling like a fool. IIRC we averaged 75 mpg. The winner got 92 mpg. The car felt like it had concrete tires & no way in today's world could you drive like that & not get shot by a road raging driver you are holding up.
My take is 32 PSI to 35 PSI for my car. Same for my son's Fit.
Old Apr 10, 2018 | 02:51 PM
Uncle Gary's Avatar
I run 35 psi front/34 psi rear. Mostly driver only.
Old Apr 10, 2018 | 06:30 PM
Bob Levine's Avatar
Also run 28 PSI.
Better mileage and handling on my 2016 LX.
Old Apr 12, 2018 | 04:45 PM
CommanderSlug's Avatar
Anyone running lower pressure in the rear? I run 38 front & 30 rear when not carrying load/passengers.
Old Apr 12, 2018 | 08:07 PM
fujisawa's Avatar
Commander, why would you want lower pressure in the rear?
OP, the recommended tire pressure is on the sticker on the driver's door jamb. The max pressure the tire is rated for is on the sidewall. Somewhere between the two is where you can play to find your right balance between ride quality, grip and fuel economy. I run at 35 and if you go more towards the economy side I've heard a lot of people list 38 over the years.
Be aware the ride will be a bit chunky at that level .. the Fit has a lot of unsprung weight to crash over bumps. But you can experiment.
Old Apr 12, 2018 | 08:42 PM
Cuz all the weight is at the front... with that heavy engine/transmission combo... and also, for the GK the gas tank is under the driver's seat.
Old Apr 14, 2018 | 10:07 AM
last time i checked my rear passengers sit behind the gas tank.. so 36-38psi all around is best for me.
Old Apr 24, 2018 | 10:33 AM
Hawkeye's Avatar
I increased pressure from 32 to 40 psi all the way around and have seen a out a 4 mpg increase. I was high 38s on the dash MPG indicator now I am almost always over 40. I don't mind the feel of the higher pressure. Tire wear might be an issue, I'll see I guess. Thanks for all the thoughtful responses.
Old Apr 25, 2018 | 07:10 AM
psamtik's Avatar
Your attempt to save maybe 2-3 MPG is going to cost you:
- Traction
- Tire wear
- Comfort
Let's SAY your Fit achieves 38MPG on 33-34 psi tires (which is spec).
Let's say your Fit achieves 42MPG on 40 psi tires.
Over the course of 10k miles, you will have saved a whopping 24.9 gallons of gas ~ about $87.1 at $3.50 per gallon.
In return, you'll wear out tires inner edges that much sooner, and compromise your own safety. I hope you forget to let the air out of your tires in the summer, and let them sit at a solid 50psi until they fail.
What muppets we have on the road these days...
Old Apr 25, 2018 | 08:37 AM
Hawkeye's Avatar
Thanks for spending the time posting a well reasoned and unfortunately needlessly judgmental response.
I’’m happy to check my psi and try different pressures. I’ll be sure to report back if tire wear becomes a significant factor. The Fit seems to handle as before. The ride quality might be a touch stiffer but nearly an imperceptible change from 32 psi.
The 2-3 mpg change gets me over 40 on the dash readout on almost every drive and this for me is a goal that makes driving fun.
I’ve only fueled up 10 times and at 3 different pressures. Once I get more hand calculated data I’ll post back.
I might try 45 psi then 50 psi. Then I’ll really be tempting disaster.
Muppets?
SlamminRC
30
Aug 29, 2014 09:47 PM
MIAMIFIT
Feb 18, 2010 12:22 PM
bojackson63044
Aug 15, 2009 04:30 PM
Bryan-Guy-Status
Jun 18, 2009 10:21 PM
Se7enlawliet
Sep 26, 2008 02:43 AM
