P0420 code issue
Old Apr 24, 2018 | 01:11 PM
Great Evil's Avatar
P0420 code issue
I just got a P0420 code - catalyst system efficiency below threshold bank 1. Will changing the down stream o2 sensor fix this issue?
2015 with 95k. Sometimes idles rough on cold start.
Old Apr 24, 2018 | 08:42 PM
bigdeezy's Avatar
Carbon buildup?
Old Apr 24, 2018 | 09:07 PM
Great Evil's Avatar
Originally Posted by bigdeezy
Carbon buildup?
I hope not. I went through that nightmare with my Mini Cooper S a few years back. If it is carbon build up, then I am getting rid of this thing ASAP.
Old Apr 24, 2018 | 09:57 PM
ezone's Avatar
Originally Posted by Great Evil
I just got a P0420 code....
Nope.
Old Apr 25, 2018 | 07:28 AM
bigdeezy's Avatar
Originally Posted by ezone
Nope.
I agree with ezone. I’ve never had a new downstream O2 sensor fix a p0420. It’s always been a bad cat. Sorry to be a negative Nancy.
Old Apr 25, 2018 | 10:48 AM
ezone's Avatar
On the DI engines the cat code P0420 is very likely to be caused by failed fuel injectors, in my experience.
One or two injectors squirting too rich can and will cause a cat failure code, and it can set that cat code without setting misfire or injector balance (trim) codes even when the injectors are the root cause.
Most of the time this requires replacing the injectors, then let the car go so we can wait and see if the cat code returns later.
The only scanner I know that can run the fuel injector self tests is the dealers HDS scanner
Old Apr 25, 2018 | 12:00 PM
Great Evil's Avatar
Well, I reset the code and it hasn’t come back yet.
Besides using the HDS scanner, are there any other symptoms I should be on the lookout for that would indicate bad injectors?
Old Apr 25, 2018 | 06:59 PM
ezone's Avatar
Wait til the code returns?
IDK if reading spark plugs would give a clue, but it may be worth a shot.
Sometimes I see code P219A when there is an injector(s) overfueling, but other times not.
Old Apr 26, 2018 | 08:55 AM
bigdeezy's Avatar
ezone thanks for the additional info! My experience has always been with non-DI p0420 codes. Usually bad coil or old plugs and the person waits to darn long and burns the cat up. DI wise I’ve had to deal with carbon buildup but never went long enough to get a p0420 code. Overfuelling makes a lot of sense. Thanks again!
Old Feb 9, 2025 | 08:23 PM
Lucky_luke's Avatar
new member with P0420 Fit 2015 TSB and some diag.
i know its an old Post BUT im have this issue, and you guys are the closest of my diag all around the internet
So here we go, I'm a mechanic for lil bit less then 20years, just buy a 280K km fit at the scrap yard xDDD and i had couple issue, including this one (p0420), cleared, and come back 20-30km later , 2time. so i found couple solution so far, found the TSB for 2015 (all) and 2016 (some) : TSB https://static.nhtsa.gov/odi/tsbs/20...33022-9999.pdf
now im here just to say that i have a Autel Scan tool at work and i got there as soon as i found this TSB to check if i have the A/F Test function, and i have it, run the test 2 time :
so here, first time Cyl 4 too rich (probably leaking in cylinder and missfire was not that high rate has cyl 1 . then Cyl 2 came too at the second test.
So my question is: anyone have saved their injector with a Cleaner of some sort, OR Install a O2 sensor spacer to fix the trouble :
So yeah, if ur mecanic have an autel, he can run this test for you to see if its a bad injector.
TSB
File Type: pdf
Old Apr 7, 2025 | 04:59 PM
Zardiw's Avatar
I had a P0420. Fixed it by running a tank of Chevron Premium AND cleaning the air filter.....it's a K+N cleanable......
Went back to cheap gas and got the code again.......BUT, I'd already passed Smog after I fixed it, so now I'm thinking of using an EDM auto o2 sensor spacer adjustable on the downstream O2 sensor to see if the engine light will clear........
Z
Old Apr 7, 2025 | 09:34 PM
2015FITEX's Avatar
it might work to clear it....which sounds like all you need....but it might be a bad cat caused by bad fuel injectors...like ezone alludes to..on a 2015 only
Old Apr 8, 2025 | 02:38 PM
t-rd's Avatar
Run fuel injector balance test, I think that's what you did there on your scanner. I didn't even bother "cleaning" them. You can if you have the time to fudge around with a backup beater car, taking off intake manifold, putting in back on then rescan and drive to test constantly.
The failure of modern direction injection car = direct injection fuel injectors and crusted valves. $1000 that can be used on fuel or other maintenance parts but used to replace injectors instead to get 33mpg+
michael.r.brog
Sep 24, 2018 06:41 PM
Arthur33
Jun 12, 2018 07:10 AM
Alex Smith
Jan 26, 2018 08:20 AM
Santiad
Apr 2, 2014 10:24 PM
rw02kr43
Dec 2, 2010 10:57 PM
