Best Garmin GPS location
Old Jul 25, 2018 | 08:09 AM
nicholasG's Avatar
I want to add my GPS device to the car but I don't want it on the windshield. I want to use the cup holder type mount. I found that the drives side upper cup holder would be the best location for me to add my Garmin GPS. The problem is I don't want to block the air vents. Has anyone found a good solution to this.
Old Jul 25, 2018 | 08:20 AM
bach's Avatar
I use this in one of the center console cupholders but it might be flexible enough to do what you want ...
Old Jul 25, 2018 | 10:08 AM
Uncle Gary's Avatar
Mine is on a suction cup mount attached to the left side quarter window.
Not the answer you wanted, but it works for me.
Old Jul 25, 2018 | 11:23 AM
bargainguy's Avatar
Yep, Uncle Gary and I have the Garmin mounted in the same spot in the left quarter window and nestling in the space above the dash vent above the cupholder.
I find this a much better location than the windshield because it doesn't impede the front view, and there isn't that much of a side view with those thick A-pillars anyway. If there's a slight negative to that location, I find myself entering addresses with my left hand, but that's not a biggie for me.
Old Jul 25, 2018 | 03:51 PM
wasserball's Avatar
I like my Garmin GPS here.
Old Jul 25, 2018 | 10:21 PM
SHAG's Avatar
I have one mounted there also..
Old Jul 26, 2018 | 05:25 AM
UnFitRick's Avatar
I see you have a 2018 EX-L. Just curious as to why you would choose to use a standalone GPS over using Waze (love Waze...) or Google maps thru Android Auto/Apple Carplay? I guess it could be a data use issue, or an issue in areas of non-coverage? Since picking up my new Fit, I have really been loving the Android Auto...
Old Jul 26, 2018 | 06:18 AM
nicholasG's Avatar
Good question. You hit the nail on the head. Data use. I've been trying to find out how much data Apple, Google and Waze maps uses and i'm getting conflicting information. As an example. If I use Apple car play with Apple maps and have the map showing as I'm driving but I don't have a destination set, am I using data? I can't seem to get an answer to this question.
Old Jul 26, 2018 | 07:16 AM
exl500's Avatar
Android here, but you are. I can show you the phone bill where I learned this.
Old Jul 26, 2018 | 07:20 AM
nicholasG's Avatar
So you are saying that just having the map up I'm using data?
Old Jul 26, 2018 | 07:29 AM
UnFitRick's Avatar
I realize I am taking your thread a little off topic, but maybe a review of cell phone plans is in order. Not too long ago I changed my Verizon plan from 15GB/month family shared data to unlimited. It actually ended up costing less and eliminated my need to limit certain family members data usage.
Old Jul 29, 2018 | 08:35 AM
nicholasG's Avatar
I think I found a good solution to the my GPS mount. The unique cup holder on the Fit may be a great place for this Sun Visor mount and not block the air vent.
Old Jul 29, 2018 | 06:16 PM
wasserball's Avatar
I didn't find it stable enough when I use the touch screen. The GPS flops all over the place. Failed.
Old Jul 29, 2018 | 06:28 PM
nicholasG's Avatar
Maybe putting a padding in to tighten up the fit would work. Anyway thanks for the heads-up. .
Old Jul 29, 2018 | 07:54 PM
Uncle Gary's Avatar
Yes, because the maps aren’t stored on your phone, but are continually downloaded as you drive.
Old Jul 29, 2018 | 08:33 PM
nicholasG's Avatar
Thanks very much for the clarification.
Old Jul 30, 2018 | 08:04 PM
vinylengraver's Avatar
It is important to note that Google Maps does indeed give the option to use maps in off-line mode.
They are downloaded to your phone, and remain static, until updated (via Wi-Fi for example)
You do not get real-time traffic info and have to plan ahead (where are you going to be when you need directions) but you can use any capable phone, even without a SIM card.
For travel in Europe I often use MAPS.ME app (also in static mode)
Saves you a ton on roaming charges. And again, your phone needs no plan just for GPS function.
But it needs to have a built-in GPS hardware.
Unfortunately, as far as I know this does not work with Android Auto. But my car does not have it, so...
I use my phone standalone and on a budget.
Old Aug 1, 2018 | 07:46 AM
nicholasG's Avatar
Finally found what I think is the best mounting device and location for the car. The company is ProClip https://www.proclipusa.com.
Old Aug 1, 2018 | 10:34 AM
fitchet's Avatar
Personally, I love my dedicated navigation GPS Garmin. And mine is old.
I like NOT having to use my phone.
Garmin has fought back with some really nice "Systems" that offer a lot of benefits and features all in one.
We are definitely however living in the age of the "Smart Phone", a tool everyone expects to do, a Swiss Army Knife number of tasks.
Maybe I'm just becoming Jurassic, in so much as I remember when you bought a Phone, A Camera, A Walkman, all as separate products.
Old Aug 1, 2018 | 12:53 PM
nicholasG's Avatar
I think you're right. Dedicated is ALWAYS better than all-in-one. Also, cell towers are on the ground while GPS is on satellites. If cell towers go down or interfered with like, rural or mountainous areas etc..., you're sunk. Data may also be an issue. Off line maps are good as long as you don't alter your route. If that's being Jurassic I'm joining the club.
